Serpent to 1/10th EP Touring Kit S400 >
Old 10-14-2007, 09:16 PM
  #616
Moderator
pc9840's Avatar
Default LiPo
Is anyone running the Orion Platnium lipo in the car? How does it fit?
pc9840 is offline
Old 10-15-2007, 01:34 AM
  #617
jo90's Avatar
Ran the car for it's first indoor competitve meet at Carpet Wars. Running in 19t I placed the car 7th on the grid and finished 7th too. The car was excellent, it ran so well. The setup I had was spot on for me and allowed me to 'learn' 19t as I have never driven this before.
Really pleased with the S400 on this outing, was only hoping to be in the top 10 and I achieved that. Now I can raise the bar !
Rug Racers this weekend so more after that
jo90 is offline
Old 10-15-2007, 04:34 AM
  #618
Trader Rating: 19 (100%+)
It doesn't fir like it is soppose to like under the bulkhead. But I run one anyways I put it in like a normal pack it hangs off the chassis a couple millimeter and add the extra weight to the inside. I will try to get a pic of it up here soon!!
Bryan
teammidget lilB is offline
Old 10-15-2007, 04:59 AM
  #619
Just intrested why you guys want to change things like Diffs and Pullys for ones from other cars. The car is awsome as kit and just needs dialing to each track.
Nick Simpson is offline
Old 10-15-2007, 07:18 AM
  #620
Moderator
pc9840's Avatar
Default LiPo
Thanks lilb -- I would like to take a look at that pic when you get a chance. Interested to see if I can do something during the inital build to make it fit a little better.
pc9840 is offline
Old 10-15-2007, 09:13 AM
  #621
yyhayyim's Avatar
Trader Rating: 26 (100%+)
The Orion 3200 fits fine. its the orion 4800 that have a clearance issue. The only way to get them to fit is to dremmel off about 2mm from the bulkhead...not the battery's fault...its the super-low CG bulkheads...its like wives...cant live with them, cant live without 'em...either shave off the 2mm, or use a 3200...or try LilB's set up...
yyhayyim is offline
Old 10-15-2007, 09:45 AM
  #622
Originally Posted by yyhayyim
The acer bearings are top notch. many nitro and EP TC's use them- they are really good. you wont go wrong with them.
You can also try "boca bearings".
thanks!
Govert is offline
Old 10-15-2007, 10:03 AM
  #623
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Bryan
i saw his car yesterday and the battery looks fine , his car was fast!
Marcos.J is offline
Old 10-15-2007, 10:10 AM
  #624
Nathan Parker's Avatar
Need to shed some weight off the S400
Where should we start?
Nathan Parker is offline
Old 10-15-2007, 10:13 AM
  #625
Super Moderator
Marcos.J's Avatar
electronics & battery
Marcos.J is offline
Old 10-15-2007, 10:17 AM
  #626
Unfortunatley Marcos
Thats the problem 5 Cell Brushless and My car weighs in at 1470 need to shed some weight off the car itself
Old 10-15-2007, 10:21 AM
  #627
Super Moderator
Marcos.J's Avatar
when i ran 5 cell's on my MI3 i changed all the hinge pins ,turnbuckles and screws
also if you are not using the Orion motor already, you may want to get one its alot lighter than novak
Marcos.J is offline
Old 10-15-2007, 10:30 AM
  #628
I`m Running Nosram speedo and motor
Think it may have to be the works screws hinge pins turnbuckles
Old 10-15-2007, 12:15 PM
  #629
yyhayyim's Avatar
Nathan, here's what I'd recommend:
#1- use the Yokomo BD rear diff, w/ serpent pulley so you have the same gearing...this will reduce some weight and rotational mass for quicker acceleration. The Yoko BD diffs will last a long time even with mod and cheaper...
#2- Go for aluminum or Titanium screws, Titanium hinge pins, as Marcos recommended
#3- Use tamiya 46mm rear aluminum bones
#4- As far as Motors- If your running mod- get your hands on an LRP 3.5 or 4.5 motor- they are 165g, which is much less than Novak's 189g, and similar motor. Or my favorite, the Trinity N60, which weighs only 156g! Its fast and runs cool. If you cant get those then run an Orion Vortex BL motor.
If you are running 19T and below, for 19T, run Orion Vortex 10.5 Bl motor...its the lightest. For stock, run the LRP 13.5 BL motor...
yyhayyim is offline
Old 10-15-2007, 12:17 PM
  #630
yyhayyim's Avatar
So that's where he was...
yyhayyim is offline
