Like Tree387Likes
JConcepts Thread
Old 08-01-2012, 06:00 PM
  #5236
RCJesus's Avatar
edit: double post
RCJesus is offline
  #5237
RCJesus's Avatar
are these the inserts that come with SC tires?
http://www.amainhobbies.com/product_...-Insert-Firm-2
One set of tires I got from JC for Short course seemed to have a lighter shade of blue inserts are they different?
RCJesus is offline
Old 08-02-2012, 05:44 AM
  #5238
PW
PW's Avatar
Yes, they are "closed cell' blue inserts. Originally the tires came with a molded insert that was a lighter color, but that was over a year ago.
PW is offline
Old 08-05-2012, 08:30 PM
  #5239
dizzy1's Avatar
Trader Rating: 29 (100%+)
What screw is everyone switching to on the SC10 clamping hex's? Just got them and didn't even snug up the screw and its stripped. Anyone tried 2mm screw or longer?
dizzy1 is offline
Old 08-05-2012, 09:06 PM
  #5240
symmetricon's Avatar
Trader Rating: 27 (100%+)
What tire would give the closest handling characteristics to the ifmar pins for 4wd buggy? The track I runs tire of choice is ifmar pins for 2wd buggy, but the tire is no longer made for the front, and since I just started racing 4wd buggy, I'm trying to figurebuot what to run. I tried holeshot 2.0 front and rear, but they lacked some side bite, so would goosbumps be a step in the right direction, or would you recommend something else?
The track is hard packed sand/dirt with dust, and is very slick when dry. It gets watered between heats and then is pretty tacky, but develops a good bit of loam in the corners, then drys out and is even looser, and suggestions would be great.
symmetricon is offline
Old 08-05-2012, 10:06 PM
  #5241
ray_munday's Avatar
Try the JC Flip Outs. They are my 'go to' tyre in the looser conditions. Their pin size is similar to IFMAR pins but with additional bars for forward traction.
Ray
ray_munday is offline
Old 08-06-2012, 03:09 AM
  #5242
DirtRacer68's Avatar
Trader Rating: 14 (100%+)
Does anyone have a picture of the new jconcepts sway bar installed on a Sc10?
DirtRacer68 is online now
Old 08-06-2012, 03:37 AM
  #5243
samuelsonmark71's Avatar
Trader Rating: 22 (100%+)
I used a 2mm longer strew from the get go. I think Im using ofna 2x6mm screws on them to be exact. Works great
samuelsonmark71 is offline
Old 08-06-2012, 04:07 AM
  #5244
Jmuck69's Avatar
What were the new front tires that Maifield was running at the Shootout? They looked liked a Pressure Points variation.
Jmuck69 is offline
Old 08-06-2012, 07:06 AM
  #5245
PW
PW's Avatar
Like Samuelson post; the 6mm length screw works well. We are currently in the process of converting ours from 5mm to 6mm.
Ray is spot on; the Flipouts would be the way to go - Click Here
It was a hand-cut tire for testing purposes only. Maifield and winner Steven Hartson used standard orange Bar Codes in the mains.
PW is offline
Old 08-06-2012, 08:55 AM
  #5246
Trader Rating: 36 (100%+)
Hey Paul,
What tire/compound is going to be good at the Clash for buggy, stadium truck and SC?
Jonathan Paulk is offline
Old 08-06-2012, 09:49 AM
  #5247
Thanks guys, I will try them out!
Old 08-06-2012, 10:13 AM
  #5248
PW
PW's Avatar
Originally Posted by Jonathan Paulk
Hey Paul,
I'm thinking Bar Codes front and rear on buggy and truck and either Bar Codes or Pressure Points for SCT. Green or Blue rear and maybe orange front.
During the nitro race last month it was super grooved up, but they didn't sweep/clean the track for 1/10th scale, so I ran 3D's in buggy and PP's in SCT. For the Clash, we will be brooming the track for 10th scale .
PW is offline
Old 08-06-2012, 11:42 AM
  #5249
Thanks, Paul. I was talking to Daimon last weekend at Bashers, he mentioned that they didn't sweep it.
Old 08-06-2012, 11:52 AM
  #5250
PW
PW's Avatar
The Clash is a JConcepts race and we will make sure the track is cleaned for 1/10th classes .
PW is offline
