JConcepts Thread
#5087
Any idea if hazard wheels for the Durango DESC will be made?
#5088
V1s usually give you more forward byte over v2s and v2s have a little more side byte. I like running v1s indoor, because side byte is usually not a factor. V2s are good for out door, blue groove high byte conditions.
#5089
Still in the works; maybe mid/late June.
Not at the moment.
It's a possibility...
Sorry, no plans.
+1, 3D's for Stadium Truck would be awesome!
Buggy rear Pressure Points please!
#5091
Got the double D's all cut and glued for my fronts. Thanks PW
I think i am going to do some 3D's also.
#5093
#5096
#5100
Tire Suggestions
I run gold pressure points on +3mm offset rims on all 4 corners. Need suggestions on what tires to run on the front of my sc10. The pressure points up front are too twitchy for me. Thanks
