Yokomo MR-4TC SD
#8326
Registered User
How to fix this?
The steering is hitting the steering saver. See yellow circle in pic.
#8328
Re: How to fix this?
and I think you are using the short servo arm, you should use the tall one.
#8330
Registered User
Thanks lem2, I'll try the tall one.
NVisible, here's my old pic.
#8332
NVisible: the CGM also is a little cramped that's why I went with a low profile servo. If you go a few pages back, there is a racer who mounted his servo the other way on his SD which is perpendicular to the chassis.
#8334
Originally posted by NVisible
turn your servo 90 degrees and thats how mine is. makes it even worse.
edited: dunno if that's the way you mountit on the servo on the RS chassis but i saw one mounted that way in an SSG a few pages back. peace and happy racing!!!!
#8335
ahh, see my servo doesnt mount that way, ive got it paralell to the chassis. I assume thats the only way i can do it on this chassis? that rayspeed kit looks sweet btw
#8337
Yes, you will need to drill 2 new holes. Just remember to measure twice, drill once.
#8339
Does the Rayspeed conversion has the same body mount locations as the standard SD?
Thanks in advance!
Thanks in advance!
#8340
I would think since the rear shock tower is longer, the mounts would be moved out, the front would stay the same.
