Yokomo MR-4TC SD
#4291
KilRuf - Tamiya makes some spacers that come with the EVO III and the Surikarn. I will look up the part no. for you tonight and post it tomorrow. I think that they make both a .5mm and 1mm spacer.
Later, Lee
Later, Lee
#4292
Tamiya made some when the TA04R was released, and they're 1mm (red I think). Don't have the part number anyway.
For the bearings, I remove the grease with White spirit or F fuel or any good solvent. Of course you need to remove the C-Clip. I use my X-Acto but it's indeed a hassle.
#4293
Re: Help with stock sd bearings.
Originally posted by racenut123
How are you guys treating the bearings?Are you spraying them out and using lighter lube?Leaving them stock or soaking them?I need help as the stock bearings are really tight.Also whats the easiest way to get the c clip retainer off the bearing.It so freaking small!
#4295
R/C Tech Elite Member
Originally posted by Jeff Werner
Randman- Any way you could twist Chris's arm and get his base setup for outdoor with the SD? I ran with him in a Invite Race in Oklahoma and since switched to the SD and would love to get some of how he sets up his car. I did see where he is now running for Fukuyama Batts.
Any info would be great...or talk him into making some guest posts on this thread...lol
Jeff
Jeff
#4296
Originally posted by KilRuf
Okay question for you guys. Don't know if yall will know this. But I figure'd I'd ask here since I have a SD. Does anyone know where I can get some wheel spacers? More like a shim that goes on between the wheel hex and wheel to space the wheel out just a tad. Say about .8 or 1mm. I know I've seen David Jun use them (me thinks at least) and I don't remember if it was a Tamiya part or HPI... or something else. But would anyone here know what I'm talking about and have a part number? I need it for carpet to space the front wheel out just a tad to fit 28mm up front. It just barely rubs and I don't feel like cutting the tire down to 27mm and/or cutting the Team Suzuki spindles. Thanks
#4297
Just an update for you guys that care. Chris was running up at SoCal tonight, had a very fast car. He hit the TQ by .009 seconds over Thad Garner and his HPI Pro 4. Chris burnt his motor in that run, and chewed up the tires pretty good as well, unfortunately we dont have too much time on Tuesdays, so Chris threw in a new motor, and I glued up a set of tires for him. We should have scrubbed the tires in, because they wouldn't catch traction at the beginning of the race, and Thad got away from him. Chris is an awesome driver to watch even when his car isn't working, and he did give a good show.
#4298
Randman,
Was CT running Fuku cells tonight??
#4299
Hi Guys,
I believe the wheel spacer kit is part number TAM53488 (man, if I can pull part number out off the top of my head...I think I'm in the warehouse waaay too much ) This pack comes with a variety of thickness.
Steve Wang
Steve Wang
#4301
53646 WHEEL SPACER SET BLUE
53647 WHEEL SPACER SET RED
#4303
square titanium axles and bones
#4304
KilRuf - The individual parts no.s for the spacers are:
9805798 1.0 Red
9805899 0.5 Blue
These are the no.s from the EVO III Surikarn kit.
Later, Lee
9805798 1.0 Red
9805899 0.5 Blue
Later, Lee
#4305
Hey guys..
Just got my SSG put together and the Novak SS installed. I added my tires and my front end is way lower than the back end. What is the droop for the front and back that everyone is currently using. I just used the same numbers from my Nitro TC3, since I tweaked that for racing, but I may go another route with the SSG.
