Yokomo MR-4TC SD
#5791
Originally posted by wcoyote
2Tenths
The screw I found was made by Hobbico. I was in Idaho at Hobbytown USA when I found it. Just bring the broken one down with you. I found them by matching up the length and threads. Found some 3mm screws up to 3mm x 20 for some other screws for my Yok.
2Tenths
#5793
Anyone experimented with custom chassis that push the cells a LONG way forward - up to one whole cells diameter forward (a la forward position in a TC3)?
#5795
No, no, it can be done - you would have to run the stock steering setup, rather than the Rayspeed or a 90 degree mod.
I've measured it up (roughly), and I reckon it would give close to a true 50/50 front/rear weight distribution (slightly more to the front if anything). Standard is about 47/53. Just wanted to see if anyone had done something similar before I get one made up.
#5797
Randman is Scott Tomosello running the Stockton race...?
#5798
Yes, Stockton Raceway is Scott Tomasello's track.
#5800
What we found when testing this was that with the extra weight up front we actually had too much weight on the front. The battery moved forward 8mm and no extra weight was the maximum that felt good so that's why the production chassis has the battery 4mm front. This way you will be able to change the weight distribution with extra weight within the area that seems to work with this car.
#5801
Sosidge. Randman and all. greetings from Malta.
If you look back about 4 or 5 pages I described how I cut my own carbon chassis, and this has the cells moved right forward.
I am using the Rayspeed geometry. in fact I use a Rayspeed top deck and towers. You just need to have the servo turnbuckle operating ahead of the steering posts instead of behind them. Easily done.
I have not only moved the cells forward, but also further towards the centre of the chassis.
Believe me I noticed the difference straight away. it is so much more responsive and precise.
Good luck.
Joe from sunny Malta.
Good luck.
#5802
NEWS !
Japan company ( Team Product D )news !!
[email protected]
this company will in 17th onsale
new patent gear ratio in SD gear set !
hope fast see this product photo & use this patent gear ratio in my SD .
[email protected]
#5803
R/C Tech Elite Member
Good luck.
Good luck.
