Team Losi JRXS Type-R
#9481
For those who have asked about this, attached find the files.
If you think something is missing, please let me know and I will add it, or you can do it on your own.
You can use this for qualifiers and mains, create a new copy of the worksheet and rename it.
Use it to keep track of your progress.
This sheet helped my progress at the last race I participated in and it helps you track your changes. When making changes, do only one or two at a time, that way you will be able to recognize the difference from one setup to the next. This will help you achieve faster lap times, and remember drive slow to go fast!!
Enjoy
Enjoy
#9483
It's hard to see from the pics but we've changed the design from a 5mm thick shaft to 4mm. This has the advantage of using the kit bearings.
By using a screw, rather than an E clip, to keep the left pully on means the whole assembly is very solid. There is no more backlash like the standard parts.
After losing a race from my speed control coming loose I came up with this:
It gives you a lot more area for the servo tape yet otherwise works the same as the standard part.
#9484
Dragonfire, seeing your car tear around the track at warp speed on Sunday with a 3.5 was the best test yet for the Layshaft.
#9486
#9487
i haven't been on here in quite some time... what lipos fit the type r well? i'm currently using orion 3200's and have pretty much reached the point where I need a bit more.
i'm running the steel tray and cut down the flanges on my pulleys. i'd prefer to not do any more mods than that to accomodate a battery.
any of the SMC's fit?
#9488
hey guys
not 100% if i am going to go losi but i am looking and understand you guys make some mods to the front end and steering rack, anyone have some part #'s???
Chris
Chris
#9489
Not really mods. The type r comes with a "JR" Link. We just take and replace it with a regular ballstud and camber link.
You'll need:
LOSA1233 Ball stud
LOSA6017 ballcups
*LOSA6532 Turnbuckles
*You can either get these or get one inch lunsford turnbuckles for the back of the car and use the stock ones in the front.
You'll need:
LOSA1233 Ball stud
LOSA6017 ballcups
#9490
thanks jole that is what i was talking about . . .
cant find it on the site i am using though . . .
#9492
ron,
thinking about it . . .LOL
#9494
what lipo's you run in the type R, i know it has to been a certain type with the way the wires run???
anyone have any idea who might have the steel lipo tray in stock???
