Team Losi JRXS Type-R
#9331
Here is most of Mike's setups plus a slew of others.
http://www.petitrc.com/view_news.php?id=4620
I tried Mike's Snowbirds, IIC, and Cleveland setups. All of them have been well balanced on the track with Sorex 28s. After doing so I took the fastest one and adjusted from there and found some more speed as I adjusted the setups to my driving style and very tight track.
#9333
The oneway in 17.5 is a personal preference. I wouldn't run one even in 540 but then again my brother loves running diffs or oneways in 17.5. I suggest trying a diff 1st as it costs nothing to try. If you like the extra steering then get a oneway. I will prolly do another order from stormer mid-end next month after I see what wears on this chassis (so far only front outdrives). If you need one I can add it to the order then.
#9335
The internal drive ratio changes with the 41T pulley installed at both the front and rear. I believe it is 1.786 with 41T's.
#9336
Location: Colorado, USA, The land of the free and the home of the brave!
It will drop the internal from 1.826 to a 1.7826 (both pullies being 41 tooth)3.5 devided by 1.7826 would be 1.963424, which is the effective spur/pinion ratio you would need to obtain the 3.5 FDR.What you would need to do then is devide the spur tooth count by 1.963424, which would give you an approximation as to what pinion you would use. For a 118 tooth spur and 41 tooth pulleys front and back, you would need a 60 tooth pinion to obtain a close to 3.5 FDR. Simple algebra is all that's required to figure this out.
#9339
Thanks. Great info.
I have another question. I ran this weekend at SS raceway in Tampa and kept having problems with my front spool coming loose. Attached is the instructions for the differential assembly that I used for building the spool. There are not instructions for spool that I have found. I followed the instruction for the diff except I left out the diff balls but used everything else.
#9344
Use a very small amount of super glue (CA) on the tip of the thread when you bolt in the diff screw. This will help lock it in place and also will increase the size of the threads a little so next time it is tight as well. I haven't had mine come loose once since I did this (both front and back diff/spool) and both can be dissasembled and reasembled like normal without any need for more glue.
