Team Associated TC5
Suspended
You will only need to replace the top hardware with 5mm ball studs. Use the same nuts that hold on the top bushings and you should be all set.
what about gearing ?
1 - Your are going to have to solder on a battery connector at the least.. If your doing speed runs id suggest the Mamba Max Pro/9000kv motor combo
2- Get a 2S lipo, as big (capacity wise) as your budget will allow.
3- Id get an Onyx 230 charger, does a/c and d/c, only $85
4- Again, depends on your budget. Id get a futaba 9551, they are $85 I believe. For just blasting up and down the street, you could probably get away with something cheaper.
Suspended
It is simple.
Lipo 1 cell has 3.7V (1s), so 7.4V is 2 cell packet (2s), 11.1V is 3 cell packet (3s).
When you got for example 7.4V 3400mAh 20C packet, you can get from this
3.4*20 = 68A const, another packet, 5300mAh/50C -> 5.3*50= 265A
If more C then packet should be better.
Hope this help
Regards!
m
Hope this help
Regards!
m
It is simple.
Hope this help
Regards!
m
Hope this help
Regards!
m
7.4v 2s or 11.1v 3s ?
Li-po
7.4 2s, but you need this AE optional part - #31257
Suspended
Suspended
On a different note . . . .
I was running my car last Sunday, and one of the screws that holds the front suspension arm mount came loose, fell out, and all hell broke loose.
Keep in mind, I bought this car off ebay as an assembled roller, virtually new w/o scratches or any wear. I have a TA05-R I bought new and used blue thread locking compound on all the screws fastened to metal parts.
After realizing I lost a spacer and two shims for the inner hinge pin, I decided to tear the car apart. I found at least a dozen other screws fastened to metal were very loose as well.
As I tore the rest of the chassis down, I noticed that whatever was used as a thread locking compound looked like CA glue; other screws had a cakey white powder on their threads.
Needless to say, I am rebuilding my kit from ground zero, and will be using the same TL compound as I did on my TA05-R.
I may or may not be barking up the right tree, however it needs to be said; substituting the right thing will only cost more later down the road!!!!
I use CA glue on a regular basis, for resin model kits and regular models, and have used it for decades.
CA glue is brittle when dry, and no matter how much is used, will crack apart under tension.
I highly suggest against substitutions, unless in a pinch at the track where it's only needed for a few heats.
TC6 is DONE!
TC6 is DONE!!!
http://www.redrc.net/2010/06/exclusive-associated-tc6/
http://events.redrc.net/2010/06/new-...ssociated-tc6/
Now, Rick, question is how and which parts we can use from tc5 to tc6?
I mean, get new chassis and use old spares at new one.
For me, new tc6 is nice but ...
TC6 is DONE!!!
