Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 08-25-2008, 05:54 PM
  #7006
katfish317's Avatar
Well today I just got my TIR layshaft and CVD's in the car, the cvd's are awesome if you do not have them, get them!! They free up the car alot in turns and do not bind up at all at full lock. They are in stock at Titanium Racing they just do not show it on the website, the only drawback was waiting fifteen days to get them.
katfish317 is offline
Old 08-25-2008, 06:18 PM
  #7007
yodace's Avatar
The robinson 66 spur 48p rubed on the top deck.
will be racing 13.5. i like it much better then mod>>>
yodace is offline
Old 08-25-2008, 10:22 PM
  #7008
hanzo3's Avatar
Trader Rating: 55 (100%+)
I am using a 64p spur gear. The screw that attaches the spur seems to rub. do I need to shave down the screw?
hanzo3 is offline
Old 08-25-2008, 10:43 PM
  #7009
K_Spec_RC's Avatar
I run RW 64 pitch spur gears on my TC5 with no problems. They are a bit thinner than the Kimbrough gears so I have not really had any issues with the screws rubbing on the top deck.
hanzo3 : Check and make sure you are using the shorter 4mm screws instead of the 6mm ones. I made this mistake when initially building my car and encountered the same problem.
K_Spec_RC is offline
Old 08-26-2008, 12:28 AM
  #7010
Robert_K's Avatar
I use a body reamer to dril out the spurgear holes. Then i use small flathead screws instead of the ball heads. Now the screws will not touch the topdeck any more.
The JAAD Racing spool is superb! really love that one!
Personally I don't like the slipper spool nor the rubber O rings on the topdeck, and got rid of them.
Greetings
Robert Krens
Robert_K is offline
Old 08-26-2008, 03:58 AM
  #7011
nutsisneat's Avatar
@ Jaad-spool users:
Do you know an online store where i can get the delrin outdrives only?
THX...
nutsisneat is offline
Old 08-26-2008, 06:31 AM
  #7012
Robert_K's Avatar
Originally Posted by nutsisneat
@ Jaad-spool users:
THX...
I'd orderd them at Precision RC, but there not in stock any more, but here they are:
http://www.muchmoreracing.com/store/...x&cPath=32_135
Greetings Robert Krens
Robert_K is offline
Old 08-26-2008, 06:52 AM
  #7013
Trader Rating: 38 (100%+)
I bought the last of the outdrives from Precision about a month ago.
or8ital is offline
Old 08-26-2008, 08:29 AM
  #7014
STLNLST's Avatar
Trader Rating: 32 (100%+)
So everyone now knows who they should be mad at.....
STLNLST is offline
Old 08-26-2008, 09:21 AM
  #7015
Sorry! Ha ha.. Not to mention I sold the car with the spool in it and still had spares...
I actually like the slipper spool better. No broken blades this weekend and no play in it like I would get with the JAAD spool over time. I did have to use the old style white Associated t-nut in it with a generous amount of blue loctite. The t-nut that comes with the slipper spool doesnt want to stay tight.
or8ital is offline
Old 08-26-2008, 03:50 PM
  #7016
quietstorm76's Avatar
Trader Rating: 12 (100%+)
The 4 o-ring mod worked great. I can feel that the car is more planted in the rear. Very stable under braking. Loving the car more and more. Thanks for all the info guys.
quietstorm76 is offline
Old 08-26-2008, 08:40 PM
  #7017
Having some issues finding a t-nut for the rear alloy diffs on my tc5r.
I have a spare plastic outdrive kit but he t-nut that comes with it does not seem to fit very well, the 'wings' are thinner.
Is there a part number for a t-nut to suit the alloy outdrives?
itchynads is offline
Old 08-26-2008, 08:44 PM
  #7018
yodace's Avatar
Whats the part number for the Orings? Are they the same has the ones used in the shocks?
yodace is offline
Old 08-26-2008, 08:50 PM
  #7019
louielou's Avatar
Trader Rating: 16 (100%+)
i need to find out where i can purchase an aftermarket spool for my tc5 that does not need to use blades, that is alot freer and loser through turns, durability and longevity is important, and just uses dogbones from the tc5. Please let me know exactly everthing i need to purchase so i don't have to wait weeks for spool parts to arrive. i want to order everthing at once. i know alot of these companies are located over seas. i know alot of u guys have experiences with these aftermarket spools, so help would be appreciated.
i noticed the steel solid axle on the muchmore uk site,does this just use the dogbones from the tc5???
Luis
louielou is offline
Old 08-26-2008, 08:58 PM
  #7020
yodace's Avatar
My stock spool seems ok? Only four runs on it...
Dum question:when u say blades what are u guys referring to?
I looked on the Jaad site for after market spools, all i saw was tamiya parts?
yodace is offline
