Novarossi engines thread
#2761
Reïnstall all the bearings, I had it with a R&B engine where the frontbearing was not seated well.
#2763
Pass you soon...
#2764
Not sure about the 353. but I measured my 3SCT tuned and with no shims; it has a real head clearance of a .30mm so for 20% i would add .15mm shim. the engine comes with a .30mm shim. I install this for 25% which gives me a total head clearance of .60mm. A little fat for 25% but better to be safe.
Adding .40mm of shims would get around .70mm head clearance this is a little too much for 20% your low end will suffer.
Pass you soon...
Pass you soon...
#2765
I can only speak for the 3sct tuned version. But my gut says they would be the same. I don't think they would change the stroke between these two engines. Maybe timing not stroke. Again I'm really not sure.
Pass you soon...
#2766
#2769
shimming...
unless i need to get a special collet, i used the collet that came with the engine...
#2770
Usually the black steel ones that come with most Nova motors work perfect.
Another option is to find a NTC3 clutch bolt and shim kit. It comes with a few tiny little shims that fit over the bolt between the end of the crank and the holder/retainer whatever that thing is called (the piece the thrust bearing rides on). That can give you the few tenths of a mm you need.
#2771
Hi, I was wondering if anyone could give me the factory settings, including mid speed needle, for the MR12 with turbo head? Any help would be appreciated!
#2772
The mid needle should be flush with the carb body. Don't recall the others.
#2773
I had the same issue.
I shaved .5mm of the the collet by sanding it on emery cloth making sure it was taken off like it was machined off.
It did the job, I just get .3mm endplay, with .4mm fly wheel to crank case clearance.
I have a GRP .21 and only have .4mm of clearance with standard GRP collet.
Not sure why I was the only one with the problem because I can install clutches blindfolded.
#2774
Why is there like 2 holes on the sides of the crankcases of Nova .21 engines.
When attaching the header do you wrap one large spring all the way around and 2 smaller ones on either side because I only got one large spring with my header.
Im new to Nova .21 engines as I have always run Ninjas and GRPs
#2775
Yep I three spring them. One long one and two short ones.
