Tamiya TRF418
#543
Tamiya has these, number 42102
RC TRF Special Damper Set - Hard Black Coating
http://www.tamiyausa.com/items/radio...mper-set-42102
#545
those are TB04 Pro shocks. 4mm shorter. Also works on m-chassis and TA06 with different shock towers.
#546
42102 aren't TB04 shocks. They are the standard size. However they lack the large diameter spring retainers that the 418 uses and have a few other detail differences too. Still great shocks, but not a like-for-like replacement.
#547
Sorry
My bad and I apologize. I simply posted up what Tamiya offers as a TRF damper set for their sedans. To my knowledge (which I admit, is somewhat limited) Tamiya does not offer a complete 418 damper set. I’m sure they will down the road but no signs of anything at the moment.
Torq, the TB04 dampers you’re referring to are the ones from TB04 Pro kit. That set is item number 42273. Those have a short body and short cap which is all together different than any other set of dampers Tamiya offers…I think.
Anyway, sorry again for any confusion I may have caused.
#552
New TRF418 parts are available at TQ.
http://www.tqrcracing.com/shop/parts...arts_p_id=7320
FYI, Thanks.
FYI, Thanks.
#555
Sorry if this has been mentioned before but I was just on the Tamiya USA web site and under the Special Features descriptions for the 418 it says:
"Special feature 8 : Includes a 20T pinion gear for a secondary gear reduction ratio of 1.85 (Minimizes speed loss when off throttle)"
Did anyone actually get this 20 tooth pinion because I don't recall seeing one in my kit?
