Like Tree2Likes
Tamiya TRF418
Old 01-26-2014, 12:23 PM
  #556
They are referring to the 20t pulleys on the shaft. (replacing the 19t ones from the 417)
Qatmix is offline
Old 01-26-2014, 01:30 PM
  #557
Finally finished my build and review, managed to get a really good set-up for carpet 17.5 blinky as well
http://www.thercracer.com/2014/01/ta...nd-review.html
Qatmix is offline
Old 01-26-2014, 03:52 PM
  #558
Raman's Avatar
Trader Rating: 94 (100%+)
Tamiya USA is listing the 42270 TRF418 as discontinued? LOL ahhhhhh come again?
http://www.tamiyausa.com/items/radio...ssis-kit-42270
Raman is online now
Old 01-26-2014, 07:14 PM
  #559
xrayaustin's Avatar
Trader Rating: 12 (93%+)
I'm sure that's just their way of saying they're out of stock and on backorder. The car isn't discontinued lol. Can't be
xrayaustin is offline
Old 01-26-2014, 09:28 PM
  #560
Raman's Avatar
I'm frequent Tamiya's site.. usually when something is out of stock it says out of stock. Most likely its an error of some sort.. unless the initial kits with the extra parts have a different part number and the standard kits will have another..
In any case, I will be buying this from the likes of Banzai or RCmart when they restock it.. after 10 long months of being a free agent (aka unemployed) I received a firm job offer. This will be my self congratulatory gift.. I feel its well deserved.
Raman is online now
Old 01-27-2014, 10:09 AM
  #561
xrayaustin's Avatar
The kits without parts being a different part number is probably the most logical explanation. Didnt even thibk about that
Old 01-27-2014, 11:04 AM
  #562
Apart from the two types in the kit, are there any more roll bars that we can fit on the 418? the 417 ones do not fit.
Qatmix is offline
Old 01-27-2014, 11:07 AM
  #563
b20btec's Avatar
Anyone got a source for a chassis kit in 450-550 range?
b20btec is offline
Old 01-27-2014, 12:25 PM
  #564
Trader Rating: 19 (100%+)
http://www.superiorhobbies.com/store...18+Chassis+Kit
Type in the code "rctech10" and get 10% off. It may even be the December kits with bonus parts, I don't know. This offer is good till the end of the month.
429racer is offline
Old 01-28-2014, 05:04 AM
  #565
b20btec's Avatar
Thanks for posting this.
b20btec is offline
Old 01-28-2014, 06:25 AM
  #566
Thanks, I had a feeling that was what they meant but the wording was suspicious. Why not call it a 20 tooth pulley? Perhaps lost in translation. LOL
c2tcardin is offline
Old 01-28-2014, 09:27 AM
  #567
Trader Rating: 42 (100%+)
because of work and schedule. I may have to get rid of my very new 418. text/call me 518-495-0703
noworries is offline
Old 01-29-2014, 08:31 AM
  #568
How many degrees of steering throw are you guys getting? I'm currently set up with one degree of positive toe and I'm getting 14 degrees equal throw without touching the radio settings. I'm using a Savox steering servo.
Old 01-29-2014, 01:18 PM
  #569
xrayaustin's Avatar
Can somebody help me out here. I got the car finalized. I'm running a bls551 with the kit servo horn. I'm not getting equal throw both directions nor am I getting maximum throw available with dual rate and epa turned up. Do I need to offset the horn? Move the link to a different hole on the horn? Try a different horn completely? I'm confused
Old 01-29-2014, 02:19 PM
  #570
rosko's Avatar
[QUOTE=xrayaustin;12955778]Can somebody help me out here. I got the car finalized. I'm running a bls551 with the kit servo horn. I'm not getting equal throw both directions nor am I getting maximum throw available with dual rate and epa turned up. Do I need to offset the horn? Move the link to a different hole on the horn? Try a different horn completely? I'm confused[/Qa
Taller servo horn helps/ or use top hole in servo saver
rosko is offline
