The Speed Passion Thread >
Like Tree57Likes
Old 07-19-2013, 06:56 PM
  #11851
Hello Y'all,
I'd appreciate some help/guidance for a problem i am having with two new Reventon Stock Club Race ESCs with 17.5 Fixed Endbell motors. I bought these to put in my sons' XXX-SCTs.
I installed the first one, and set up the transmitter. However, i do not get any throttle/brake response from the esc. I know the transmitter is working (its the Losi 2.4 Ghz that came with the trucks) as the steering is fine. The orange LED is on solid, and the red LED is blinking. During transmitter setup the motor 'beeps' as i believe it is supposed to.
Thinking i might have a bad motor, i opened the second esc/motor set. I tried the 1st motor with the 2nd speed control. This time, i turned on the esc before setting up the transmitter, and with the transmitter off. The motor ran a bit. Then i tried setting up the transmitter with the second esc, and got the same lack of throttle/brake activity as with the first.
I tried all the other combos of ESC/motor/sensor wire that i could between the two with the same effect.
What am i doing wrong? Is there a setup step i am missing? The trucks were working fine with the stock Losi ESC (but i got tired of having to clean the motors ) What could the potential problem be?
Sorry for the long post, but i would greatly appreciate help. I have two sad sons right now
EDIT: I'd like to add that i used a charged and known good Lipo, and new sensor wires.
AntiGooch is offline
Old 07-20-2013, 12:10 AM
  #11852
Xpress's Avatar
Originally Posted by Phoenix82
Hey guys. I'm having an issue with setting up my SP reventon Pro Esc. I seem to be unable to set up the drag brake in the controller (on demand) for the 3pk. and setting/advise would rock.
Nick K
The drag brake is adjusted in the esc settings not with the radio.
Xpress is offline
Old 07-20-2013, 09:49 AM
  #11853
Phoenix82's Avatar
On the 3pk. you can adjust the 3rd channel via the wheel on the handle. when If i set it to 0% it has zero brake. then i set it to 5%. it has full brakes. i dont get it??\
Howard-help!!
Nick K
Phoenix82 is offline
Old 07-21-2013, 07:54 PM
  #11854
Originally Posted by AntiGooch
Hello Y'all,
I'd appreciate some help/guidance for a problem i am having with two new Reventon Stock Club Race ESCs with 17.5 Fixed Endbell motors. I bought these to put in my sons' XXX-SCTs........
Do you have refer user manual Page7? Set the throttle channel to”REV”.
http://www.speedpassion.net/uploadfi...un01st2012.pdf
WMGary is offline
Old 07-21-2013, 10:21 PM
  #11855
Found out broken sensor cable when removing motor
I can't seem to get my speed passion MMM motor to work with Orca VX competition V3 ESC?
Is this a known problem?
It was working before with Tekin and Futaba 4pks radio system. I have reversed the throttle already and reset end points on esc
zzztech is offline
Old 07-22-2013, 09:06 AM
  #11856
The wording of the manual implies that setting the throttle channel to "REV" only applies to Futaba radios. Is that incorrect? Does it need to be done with all radio brands?
Old 07-22-2013, 09:08 AM
  #11857
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Futaba
IIGQ4U is offline
Old 07-22-2013, 09:14 AM
  #11858
Trader Rating: 17 (100%+)
It is not longer the case.....in your case, try BOTH setting, one of the setting will work.....we have tried SANWA KO and other brands...in SANWA, like M11, it will work in NORMAL position, but of their entry level unit, it has to work on REV position. They make their change by OEM the radio from someone so the "only Futaba" radio statment is no longer true...
Anyway...try both setting, one of those will work.
Solara is offline
Old 07-22-2013, 09:18 AM
  #11859
Howard-help!!
Nick K
But why are you doing that via your radio....? If you are running mechanical brake system that I can understand....but electric?
Have you try using the drag brake setting via the ESC and you don't like it...?
Solara is offline
Old 07-22-2013, 09:25 AM
  #11860
His radio will not really calibrate properly. His throttle inputs come through fine, and the ESC can find neutral, but the "ATL" setting on his 3PK seems to be causing a issue.
When the ESC and radio are calibrated with the "ATL" set to zero, he has no brakes whatsoever until he turns the "ATL" up to 5 or 10. Upon doing so, it seems he gets max brake, but in the form of drag brake. If he calibrates his ESC and radio with the "ATL" set at 100, he still has no brakes, and upon turning it down the motor starts spinning in the forward direction.
I've looked into it a bit and cannot find any other mention of the problem, and cannot really solve it with my own equipment as I'm using Airtronics radio gear.
Danny-b23 is offline
Old 07-22-2013, 09:49 AM
  #11861
Can he format (default) his model from his radio and calibrate it again...?
Solara is offline
Old 07-22-2013, 08:25 PM
  #11862
Phoenix82's Avatar
Hi Howard. Ill do a complete reset of my radio, and see what happens. Will let you know tomorrow.
Nick K
Old 07-22-2013, 10:40 PM
  #11863
Holmenkollen's Avatar
I´m having the same problem using a KO EX-1 UR.
Holmenkollen is offline
Old 07-22-2013, 11:36 PM
  #11864
Typeone's Avatar
Trader Rating: 50 (100%+)
I have a 17.5R MMM wondering what timing ring I should use for a medium size track. Also I'm using the Reventon R esc.
Typeone is offline
Old 07-26-2013, 02:55 PM
  #11865
SamuraiJack's Avatar
Trader Rating: 41 (100%+)
Default Hybrid Boot "Active" vs. "Power"
For Reventon Pro STOCK1 firmware: is Hybrid Boost Power (HB Power) the same as Hybrid Boost Active in the documentation?
SamuraiJack is offline
