The Speed Passion Thread
hello, maybe someone here can help me with the reventon pro. i just picked up 2 of these used from rctech for sale threads. i've tried to hook both of them up with the same results.
the motor is a speed passion 13.5 from the durango rtr car, airtronics rec, savox 1258 servo, and venom battery. the stock cirtix speedo works fine with all of these but both reventons make a cogging sound and barley turn the motor while making a horrible noise and the motor gets hot real quick.
what's wrong with these speedos or am i doing something wrong?
all wires have been double checked and are hooked up correctly. the sensor wire works great with the cirtix speedo.
any help would be great.
Originally Posted by Dog Runner
I'm confused as to where to get the most recent software for the reventon pro. Is it via the computer or the wifi module/app or somewhere else?
What version number is the most recent software?
If its a computer program, does it work on a Mac ?
Thanks for any help.
You can find the latest version of the software below, entitled Reventon PC Program with USB Driver V1.1.0.22:
http://www.speedpassion.net/en/download.asp
As I stated a few replies above yours, I am running the program on a Mac, but not natively.
I am running the current version of OSX and installed an old version of XP SP3 that I've had lying around.
If you aren't really computer savvy, I would skip the XP install and install Windows 7 via Bootcamp as it will be much easier.
Installing the Speed Passion program itself is pretty simple, unzip the program, install the USB driver, locate the driver in com ports and double click or right click? to assign it properly and complete the driver installation.
After that, install the PC program, connect your ESC, and the rest is simple.
Hi - is it better to run the muchmore felta 4 software with the speed passion revention pro, or is it just the same between the two? On the petit rc website, they say the muchmore is better.
the much more software is mostly better for blinky
Fragile bottom deck on Your Reventon Pro? No Probem
hi all,
hoping someone can help me
my reventon pro would switch off by itself after a race. running blinky with V20 in 17.5. esc is barely warm after the run.
any ideas?
thanks!
any ideas?
thanks!
Firmware update for LCD Professional Program card
I have 2 program boxes,
a translucent Blue one:- Reventon SMART LCD Program card, version 2 .7
and a Black one:- LCD Professional Program card, version 1.07_110119.
The black box will not connect to any of the Reventon ESC's or connect to the PC software 1.1.022
Is the black LCD Professional program card compatible with the Reventon ESC's?
What is the latest version of the Black box and how do you update it?
Fred
Fred
