Kyosho Ultima RB6 & RB6.6 Car Thread
#3617
i have not needed the alum holders to date. the new RB6 stock ones are beefed up i'm not the best driver. i haven't seen one break locally out of the 4/5 we have running.
#3621
there is enough room to only have the esc partially under the rear bulk head/ tower, my R10 is only halfway under it. there is plenty of room.
#3623
i'll post a picture when i get home later.
#3625
AND thats mid motor... in rear, we have an extra inch or inch 1/2..
#3626
I am trying a setup that calls for "Narrow blocks in rear hinge pins"
I started going through my car and parts bag. I'm totally confused because I have 2 blocks marked RF2. I assume the less beefy one is from the RB5...
Do I use the RF block and the narrow rear rear part? The narrow rear rear block is also less beefy and on the diagram it is greyed out indicating its not for this kit???
Someone please explain and maybe even tell me which parts in the diagram I should use.
Thx
Thx
The only thing I've broke on this car was the rear suspension block. This was a result of my rear tire hitting a concrete well that I shouldn't have hit at full speed. This is the only thing I've broken on my RB6 so far. You are securing a plastic block to a metal chassis, the plastic is going to give most likely every time. I'm running the gunmetal aluminum ones from the RB5 which are the same, problem solved. My SETUP calls for the Aluminum RF and Aluminum narrow block.
Part No. UMW512GM and UMW511GM
I read often that people "hear" that the rack breaks. There's about 15 people running RB6's at my local track and I haven't seen ONE person break it. Maybe it's different layouts and skill sets that factor in...
#3627
New layout...
I thought I would try some new stuff for the last race of the year...new electronics layout and shortie as well as some mods I picked up from here. I also used some titanium that I had from other cars and my RB6 with this setup weights 1595gr...not bad
And yes the esc WILL fit under the rear tower in RM configuration no matter which battery layout you use (my esc is ORCA btw)...I even managed to fit the capacitor behind the esc!
[IMG][/IMG]
[IMG][/IMG]
#3628
#3630
do it! do it! do it! do it! do it! do it!
