Schumacher Corner
I have one shim on each side at the moment, but think this is probably just a touch too much. It isn't tight, but there is virtually no float. Think i am going to get some thinner shims so i can effectively take less than 1 std shim out.
Is there any disadvantage of "float" or "left-right slop" in a belt driven car's tranny?
Originally Posted by PW
Here is Teemu's setup from the GP Carpet Wars race
Originally Posted by HarshGuy
I'm sure you heard ...but your compadre TQ's and won with his new car (even beat A-Yo's TQ). He was heard saying in the pits "can't wait for STLNLST and his EC".
Originally Posted by MortenFogh
Which droop settings did Teemu use?
Trader Rating: 32 (100%+)
hey guys just brought a hpi droop and ride hight gauge and was wonderingdo i measure to the bottom of the suspension arm or is there a better way? i hope i bought the right droop gauge?
is there a better way to measure droop?? how do u factory guys measure droop?
oops sorry p dub so u guys dont measure to the drvie shaft(heard it mentioned somewere) u just use a droop gauge (ie hpi gauge) how much droop should i run?
Teemu measures his droop from the pit board to the top of the axle. I don't really like doing it that way. I measure the droop as above ride height. Set the cars ride height where you want it. Then lift the car by the center of the shock tower with the shaft of a hex wrench just until the tires come off the ground. Then use your ride height gauge and measure your ride height again. The difference is your droop. If you set the car to 5mm ride height and lift it up until the tires are just touching and measure again and you get 8mm, you have 3mm of droop. Then use the actual droop gauge to make sure both sides are even. I usually run between 3 and 5mm of droop above ride height.
What you can do is make up a spreadsheet that lists combinations of tyre diam, desired ride height, and desired droop (above ride height)- and then gives you an axle height measurement.
The formula is: tyre diameter/2+2-rideheight-droop= axle height (to top of axle).
Measuring below the wishbone gives you pretty much exactly (maybe +/- 0.1mm) 20mm smaller result, so 3mm under == 23mm to axle. Hope this makes it a little easier to compare between setup-sheets.
ok i set my droop with 5mm ride hight at 5mm on my hpi droop gauge is this right?
