Team Associated B6 & B6D thread
#1696
#1698
edit, theyve responded and are sending me a replacement body. not terrible.
#1700
Tech Prophet
#1701
Who has tried the tall rear tower?
#1702
Got a race meet on the B6D, we run on loose dirt car has tons of rear grip with kit setup, had a fair bit of understeer so took the 2mm washer away on the ackerman and moved the battery foward. Got more steer with similar rear grip. Very easy to drive looking toward to racing it again.
Obligatory photos. Weight is 1530g as seen here.
#1703
Any comparison to a B5M or a B5R? What kind of car do you normally run? Pics of the track please
#1705
The b5r? Not even close. I've raced on some of the lowest grip dirt there is. Rear motor is a thing of the past. If you're not going faster with a mid car in those conditions you're not tuning correctly.
The thing that surprised me most is how good the b6 is right out of the box!
#1706
Did someone tried the 4 weight scale thing ?
I feel like the rear right is sightly heavier than rear left end. And seen Kinwald put some weight near the C mount too
#1707
#1708
Idler shaft question
B5's is 91011
B6's is 91132
in the parts compatibility the 91011 does not show it works on the B6 but the 91132 shows it works on the B6's and B5's.
Is there any reason the 91011 won't work on the B6?
differences other than 1 is aluminum and the other is not?
B5's is 91011
B6's is 91132
#1709
The B5M did a weird "pivot" type move in the corners. The B6/B6D doesn't do this, instead it flows through the corner. Is it faster? Slightly, yes. Is it easier to drive? YES.
#1710
I have. Yes. It's why you see the pro's ESC's on the far right side of the front, to help offset the motor weight.
