Like Tree248Likes
Xray XB4 thread
Old 02-26-2014, 07:44 PM
  #4141
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
My 14 when I gets stickers in it will look better but no to bad. I love this car they handle amazing the v2 and 14 both.
NitroXray80809 is offline
Old 02-26-2014, 08:06 PM
  #4142
elex300's Avatar
Trader Rating: 110 (100%+)
I cut the spacer section off the rear. Do I also have to dremel the plastic section of the chassis that the gear box ledge rests on so everything can lay flat on the chassis. As it sits now it wont lay flat because it hits that piece.
elex300 is offline
Old 02-26-2014, 08:19 PM
  #4143
seth556's Avatar
Trader Rating: 43 (100%+)
There's a carbon fiber shim that usually goes between the composite chassis and the gear box, when you run the gear box against the chassis you don't run the spacer. So you're really removing two spacers to do the mod.
seth556 is offline
Old 02-26-2014, 09:12 PM
  #4144
elex300's Avatar
Got it. Thanks Seth.
elex300 is offline
Old 02-27-2014, 04:31 AM
  #4145
Errokk's Avatar
Trader Rating: 13 (100%+)
Good lookin buggy!
Errokk is offline
Old 02-27-2014, 07:30 AM
  #4146
Lonestar's Avatar
Trader Rating: 14 (100%+)
Hey guys, I know this is gonna sound odd... but has anyone fiddled something to run a front one-way on the xb4?
Paul
Lonestar is offline
Old 02-27-2014, 11:58 AM
  #4147
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Trying the rear tranny mod , hope i got it right lol
http://imageshack.us/a/img850/3006/t65x.jpg
If not guess theres no turning back
Tools , parts n car pic
BDRMBULLY is offline
Old 02-27-2014, 12:17 PM
  #4148
joeymdz's Avatar
looks straight
joeymdz is offline
Old 02-27-2014, 12:32 PM
  #4149
BDRMBULLY's Avatar
I followed the contour of the back of what i cut off. Didnt think it had to be straight, tranny screws do that
Old 02-27-2014, 01:04 PM
  #4150
joeymdz's Avatar
cool... now grind down the hangers and you are set
joeymdz is offline
Old 02-27-2014, 02:07 PM
  #4151
BDRMBULLY's Avatar
I ground down the rear hanger part that over hangs the chassis, the screws didnt want to go back in properly, am i suppose to grind down the entire flat spot that sits on the chassis so the screws go back in the rear hanger properly? And does the front rear hanger need filing as well?
Old 02-27-2014, 02:24 PM
  #4152
Trader Rating: 15 (100%+)
You need to gently file the inner "rounded" edges of the RR Hanger to allow it to sit flat on the chassis. It does not require a lot of material to be removed. 7-8 passes each side with a decent file might do it. There should be no issue with screwing back down then.
The RF hanger does not need any modification.
HeavyD99 is offline
Old 02-27-2014, 02:45 PM
  #4153
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
If you don't like simply, put the removed piece back under the great case and screw everything back together. It's totally reversable. The '14 spec car comes with the rear chassis piece already modified.
Qwkrn U is offline
Old 02-27-2014, 03:28 PM
  #4154
BDRMBULLY's Avatar
Mine went down without filing the inside, just filed the part below tge chassis so it doesnt get hitched up on the track
Thanks for the timely replies
Old 02-27-2014, 10:54 PM
  #4155
V6Jim's Avatar
Not on mine. I had to file the carrier to get it to fit. Easy job though.
Jimmy
V6Jim is offline
