Like Tree248Likes
Xray XB4 thread
Old 11-22-2013, 08:03 AM
  #3391
BillyT.'s Avatar
Originally Posted by asc6000
why ? EXACTLY what is this improving ? Under what conditions is the stock arm inadequate ?
Was told by X Ray team mechanic they are must haves for high grip.
I mean, the are X-Ray parts... same guys that designed the arms designed the stiffeners... maybe they know something we don't... maybe...
BillyT. is offline
Old 11-22-2013, 09:30 AM
  #3392
Trader Rating: 15 (100%+)
Martin Bayer & other team drivers can probably tell the difference of using the carbon plates and use it to their advantage. Just keep in mind, if you need to be marshalled and cannot drive a clean heat and make clean passes at the club level, you simply need more practice! It's you, not your gear.
HeavyD99 is offline
Old 11-22-2013, 09:46 AM
  #3393
Blown up's Avatar
I had to go w/the factory xray body but any recommendations for aftermarket wings?
Blown up is offline
Old 11-22-2013, 10:02 AM
  #3394
joeymdz's Avatar
http://www.amainhobbies.com/product_...FRSVfgodyDcAsw
and If you leave a small amount of "lip" that rests on the rear shock tower.. the wing will stay straight and true for a long time
joeymdz is offline
Old 11-22-2013, 10:34 AM
  #3395
Blown up's Avatar
Good idea! Wings, body, wheels, tires on their way! Can't wait to burn some laps....
Blown up is offline
Old 11-22-2013, 11:18 AM
  #3396
ps71's Avatar
http://www.amainhobbies.com/product_...ear-Wing-Black
ps71 is offline
Old 11-24-2013, 09:57 AM
  #3397
hi i would like to buy a xb4 2014.
Rc market or rc mushroom are good place to buy?
What spare part and exotek part i need to be good
Thx a lot.
neo456 is offline
Old 11-24-2013, 11:40 AM
  #3398
oliv996's Avatar
I would suggest LMR Electra wing, they are more durable than the stock one: http://l-m-racing.co.uk/products/ind...&product_id=53
oliv996 is offline
Old 11-24-2013, 01:29 PM
  #3399
dMITIj's Avatar
So how is the new XB4 2014 compared to the "old" XB4?
and what will be good upgrades to buy right from the start?
Best Regards.
dMITIj is offline
Old 11-24-2013, 03:02 PM
  #3400
asc6000's Avatar
Any ideas how much that thing weighs ? gotta be throwing the handling off.
asc6000 is offline
Old 11-24-2013, 03:14 PM
  #3401
asc6000's Avatar
I was being facetious. Thats what they say. Only the best drivers under maximum conditions. That leaves the chassis. Which is where I believe even more mortals like you and I would benefit. Thats my point. In stock form imo the chassis is too flexible for some conditions even with all the adjustment screws in place so a stiffer chassis would allow the tuning envelope to be altered in a positive direction. Hopefully if revised it wouldn't bend either, that would be nice.
The other thing is the arm plates are more appropriate in 1/8th where the shear weight and speed of the vehicles demands a much higher level of durability. In our scale, especially on this beautiful little precise car it seems out of place to add unsprung weight to decrease arm flex. And not being facetious, exactly what is the problem ? is the flex changing something ? caster ? antisquat/antidive ? ??? what ? seriously. If I am being asked to bolt on that thing I want to know exactly why.
edit: and why not just make a stiffer arm ? lighter and not so "mickey mouse"
asc6000 is offline
Old 11-24-2013, 03:55 PM
  #3402
Chris Rakus's Avatar
Trader Rating: 17 (100%+)
Any one have any idea what the front and rear lengths of the shocks are. Think I'm going to try some kyosho shocks.
Chris Rakus is offline
Old 11-24-2013, 07:54 PM
  #3403
Quick 5 min vid of me learning our local track's new layout(crashing a lot). The bright orange buggy is my Stock XB4, need to make a few setup changes to adapt to the new track and get a lot more track time. Towards the end(after the video) I did manage to get a few good laps in before I got t-boned by a crazy SCT driver and dislodged a few parts...
+ YouTube Video
ROB784 is offline
Old 11-24-2013, 11:48 PM
  #3404
Boz
Trader Rating: 23 (100%+)
33gm uncut
Boz is offline
Old 11-25-2013, 12:30 AM
  #3405
BentKa's Avatar
https://www.facebook.com/TeamXray
New optional XB4 aluminum gear diff and steel pinion gear to be released soon
XRAY has been working on a new optional aluminum gear diff and steel pinion gear. The combination of these gears increase reliability, and also improve the drivability of the car more at high-traction tracks due to the increased weight. The aluminum gear is machined from ultra-strong Swiss 7075 T6 and is then additionally black hardcoated for maximum lifespan. For medium- and low-traction tracks, we recommend using the standard composite graphite gears which generate more traction.
Bent
BentKa is offline
