TA-05 ver.2
#1351
Not sure about the TA05 V2, but a 115 64p in the regular TA05 with the carbon fiber or aluminum spur brace will fit. It hangs out the bottom of the chassis just a bit. Running carpet was ok. The first time out on pavement I jammed it up with a pebble. Found that a 108 64p can run pretty well either carpet or pavement.
#1352
Super Moderator
thanks, i do not have the carbon or aluminum top cover, so needed a spur option that would fit inside the sriginal cover for the version two, so there is no one running a 64p spur gear that can give me the tooth number, my local hobby store has none, and i do not want to order gears that will not fit and be stuck with them, thanks again for the help
#1353
Trader Rating: 32 (100%+)
I looked into this at the track this weekend....it could be made to fit if you narrow up one side or both sides where the bearings sit on the gear diff housing and let the bearing move in closer to the center more. Its about 1 to 2mm too thick to fit in the Ta05 Bulkheads. This was all with a Spec-R 416 Gear diff.
#1354
My V2 is 2 days out on a brown truck. I took the liberty of reading through this whole thread, I just want to make sure I have all my bases covered. First, I am going to build the kit as the book says, however i have some parts coming in. These are parts that you guys recommended in this thread. 1)servo horn 2)alum diff outdrives 3)46mm cvd's...and I got some alum shocks....
This should make it pretty bulletproof, right??? Am I missing something?
#1355
If you can, I would also look into alum. steering set and sway bars also. I don't have these yet but have been recommended to get them a bunch of times.
#1356
OH wow. What a f-ed up first experience with Tamiya products. I get the box today, I open it up, all excite. First thing I know is that it's missing the body. No big deal. I pull out the book getting ready to build the kit, I notice that the bag looks like someone just pulled something through the plastic. I keep going thinking everything is going to be ok, i don't even get through the first step and I immediately know that something is off. I am missing the e clip and the washer, as well as the bushing that goes on the end of the spur shaft.
Has anyone had this problem with tamiya, or is this a seller thing?? Thing is, i bought the kit on ebay, hopefully the seller takes it back, which puts me in a bind since i am going to have to wait 1 week for it to get there, 1 week to get back.
THIS COMPLETELY AND UTTERLY BLOWS!!!!!!!!!!!!!!!!!!
#1357
I don't think you can really blame Tamiya on that, it's pretty obvious the kit was tampered with by the seller. However, if you got the TA05 V2R that just came out, that doesn't come with a body - it's intended to let the racer choose their own body. They have a ton of normal V2 variations with different bodies.
#1358
#1361
What teeth pinion and spur gear should i use if i am using a tamiya sports tuned motor?
#1363
Issue resolved. Got a couple of e-clips from a lhs, some bearings, etc. About 20 bucks worth of stuff. Got a body for 30 bucks at my lhs. I could not be happier. I am in the process of finishing this build, my speed passion 17.5 with cirtix stock esc is here also.
One question, since the SP 17.5 has holes in the motor case, should I be covering the little scoop at the bottom of the chassis to prevent debris from entering the motor????
Well, two questions. Given a stock v2, what pinion gear should I be using??? My track has a 40-50ft straight.
#1364
#1365
Right now i am running a 7.1925FDR. Speed passion 17.5 and stock club esc. I just don't want to burn anything up. Will I be OK???
