#2896
I have a Hobbywing 25A esc in my SC18. I recently picked up the 2 in 1 programming box. When I hook it up to esc all it displaysis "connecting to esc". I assume this mean I have the version 1 esc. Does anyone know if I can upgrade the software in the esc to the version 2?
#2897
Does anyone run there HW Extream stock like the Black Diamond works ??????
RE No Turbo Just a steady timing advance over the whole trottle range ??
Is this possable ?
If it is which i am sure it is can somebody suggest some settings to try please
Running the latest 119 software and a HW 21.5 motor
Thanks in advance
Is this possable ?
Thanks in advance
Unfortunately I cant give you a setup as I dont run the same setup, but either run just Boost, or turbo with a slope works really well.
Shawn
#2898
bro need help
hai otai2.....kindly someone please email me the lastest software for xerun 120a...
#2899
I'm looking foward to getting the Novak data logger installed so I can see what revs I'm actually running at round the various parts of the track.
#2901
setup sheets
Do hobbywing have setup sheets? Well for the latest fw -
I know I saw one last year when the original turbo fw was released but can't use that anymore for obvious reasons.
#2902
sent pm
[QUOTE=zleader_99;8594979]I current have SP v1.06_100617 on my HW 2in1 box. I am trying to install the latest HW soft. I have been told to install the old version of the SP then the old HW finaly to the new HW soft. I have been running the update application in admin mode.
I am tryin to back grade to the SP v1.32
This is the error I keep getting
I have sent you a PM
#2903
#2905
Cheers
#2906
Some tracks have speedtraps, (like ours) some times a speedgun is used.
With that info you can calculate your max. RPM.
For the rest drivers should focus more on car set-up and driving skills! instead of start studying log files.....
#2907
XERUN-120A-1S ESC
can you wire the esc to bypass the VB to use an external booster or receiver pack?
2 Features
2.1 Built-in DC/DC booster. Perfectly works with 1-2 cells Lipo, so the single cell class racings such as 1/12 scale competitions are easily covered by this XERUN-120A-1S ESC without an additional receiver battery.
#2908
I think in the end you will only be interested in the RPM you reach at the end of the back straight, that you atleast know you will reach your set max. boost timing.
also you want to see in what window your rpm's are. from there you can fine tune the rpm range. than you use your turbo for extra topspeed on the straight.
fine tune the setup in the infield and use the turbo for the straight. this gives you the best infield speed.
#2909
No you want the averige rpm. the highest rpm is reached on moost tracks once.
Max RPM is pretty meaningless really, as by the end of the straight, you should be at an RPM well beyond that of the end of the boost range, especially when including turbo settings.
HiH
Ed
#2910
The RPMs on the straight is actually of less interest; I spend about 2s on the straight and 12s on the rest of the track, so there's much more time to be found on the infield than the straight.
