Schumacher Corner
#2836
Trader Rating: 32 (100%+)
PRP.....They will be sold through Schumahcer USA and any hobby shop or online shop can buy from them so you can really get it from anyone. I dont know for sure if they are in stock yet last I heard they were not. As soon as I find out I will let you know.
#2837
GotyourNumber.....I have the 3mm chassis and it is alot stiffer over the stock one, its stiffer then the stock chassis with the carpet top deck.
#2838
R/C Tech Founder
I had the pleasure of meeting Adrian Martinez and Robin Schumacher at the Chicago show today, and I've got to say, these guys were great and Schumacher had one of the nicest booths at the show.
Look for pics of some new stuff up in the Chicago show coverage soon.
#2839
Info on the machined pulleys from the owner of RW racing:
Hello Bill,
Mission pulleys will be available from Schumacher Inc in your country in about two weeks. It will be cheapest for you to get some from them. They can give you information on pricing as well.
Regards,
Neil
Hello Bill,
Regards,
Neil
#2840
Yorkie: The sway bar takes away traction at whatever end it is used on. If the sway bar is on the rear, then you will have less rear traction. Most people I know either run both or only the front sway bar, depending on how soft the setup is and how high the bite. I would try moving the swaybar to the front...
#2841
Racer X,
I don't think the previous post was that clear.
I had a sway bar on the front only to start with this week as the previous week the rear end was a little loose applying power out of the tight corners.
After some suggestions from this board I went with the 8.5 deg castor also.
With the front sway bar only and the 8.5deg castor the rear end was worse. There was just far too much front end grip. I know it sounds impossible but after I removed the front sway bar, so I had none fitted, the car handled fine.
I am going to play around with shock positions next time out. I am running both front and back in the upright most position right now. I will start by moving the front shocks in a hole and see what that does.
Thanks Yorkie
Thanks Yorkie
#2842
Well in most cases, what Racer x said was right. The sway bar equals out the bios of the car. If your hookin up good in the front but ur backend is slidin all over, Do some adjustments to the back then put a swaybar in the front.Thus shedding off a little traction in the front end so the back end can equal out with the front. You see my point?
#2843
Does anybody have a good set up for carpet with foams,and the 3mm warp speed chassis.Thanks
#2846
Does anyone have a good setup for foams on carpets at this track with a 12 turn? The setup i have now is good but im sure it can be better! (i can post my current setup if you want). Also is this track big or small compared to US indoor tracks? thanks
ps. quality of the pic not that good because i had to compress it to get it under the file limit.
#2847
Clint,Bill Thanks for the kind words,Gerret thanks for the welcome,This is a pretty cool sight.Its the car.
#2848
Originally posted by IMPACTPLAYR
STLNLST- fix you sig please,-------- "ME" -------------- LOL, I don't know it just started bothering me, guess I am a little anal this morning....LOL
#2849
#2850
ahh,sorry clint. I raced some offroad in modesto last night. Ran mod in a xxx-t. I have the fastest time for eletric and also have the 2end fastest time on the whole track. Dino beat me by like 1 sec! On his Mugen Losi.
