Schumacher Corner
#5386
I wonder why Schumacher kept the Team edition so undercover?
After all the first i heard about it was when i saw it in my LHS a couple of weeks back!
#5387
"SPOOL" or "LOCKED DIFF" ????
Hello to all. Please, could anyone explain to me what is the front "SPOOL", or front "LOCKED DIFF" for MI2 and R12 Schumacher's cars? Thank you so much.
Antonio
Antonio
#5388
A SPOOL or LOCKED DIFF is a solid front diff with no diffrential action.
Spools have proven to be faster than a one way on most surfaces. They let you carry power deeper into the corner and out break one way users. They also have excellent on power steering when your car is set up right (way better than a diff).
The trick to getting your car good with a spool is to set it to turn in hard and let the rear rotate off power. This gives you all the turn in your need and the spool will yank the car our of the corner on power.
We make a spool by dissassembling the diff, removing the diff balls, throughly cleaning the diff pulley/rings/outdrives. Glue card stock (header card/business card) to one side of each diff ring. Re-assemble the diff with the card side of the rings facing towards the diff pulley and no diff balls. Tighten the diff as in the assembly instrcution but dont back it off...leave it tight. Thats it!
#5389
Originally posted by PW
Hey Ray.....The Winter Nats went very well for Schumacher It was a team of 2 (myself & Larry Pryor) against Team Mugen (Team Japan/USA 8 plus) and Team Serpent (Team Holland/USA 20 plus) which resulted in a 5th place overall finish. I think it is really something to be proud of I guess I made a huge setup mistake for the A-main and think it may have cost me at least 1 or 2 spots
I would have to compare our car (R12)with the NTC3 as far as handling, but I haven't had any issues with the car changing from brand A to B tire.
BTW: The new R12 Team edition was news to me on Monday morning I really would of love to have seen what I could have done with those much needed updates!!!!
I have concerns about the clutch and gearing choices, etc....
I ran a NTc3 one summer and it was a dream to drive when it was right. But it could turnninto a POS in a heartbeat!! LIke I said-just changing rear tires from Ellegi to Jaco in the same shore could ruin the handling. Maybe my set-up was very closeto loose anyways and the chnage in tires was enough to osh it over the edge.
#5391
Adrian, we are Schumacher distributor in Malaysia. And we would like to join this thread to share some tech and info with you. Nice to meet you here.....
#5392
Thanks for your prompt reply, Adrian.
Kind regards,
Antonio
Kind regards,
Antonio
#5394
Originally posted by RC Old Man
Will there be a conversion for the R12 from standard to team version available?
#5395
Looks like I might get on the track this weekend. I will post any new set up changes. I plan to try something every time out.....
#5397
stlnlst;
do wild bears go potty in the woods!!!,,, lol, hope the weather stays clear this weekend, racer-x and i hope to make a speedworld run on sun,,,if billy is open!!!
#5400
Old man, build the Mi2 and you will see how stiff it is...
in my opinion, it has jsut the right amount of flex for rubber outdoor...
I believe optional topdecks will be available for the rug...
Schumacher tested many thicknesses and configurations of chassis and topdecks...tons were tested at the factory..
the Mi2 has had a very long development time..and it shows on track! =)
