Schumacher Corner
#6886
stnlst the M-8 is still the bomb but the KO Propo is a good choice also!
#6888
Adam leave the front riser plates of.
Youl need to cut it to make a cross brace using longer screws with a nut so the chassis doesnt break!
#6890
mo how did you do that and what did you need
#6893
Now-a-days it really doesn't matter. You can't go wrong if you stick to Airtronics/KO Propo/Futaba. Get whatever you think looks cool...lol!
I run Airtronics because I have used their radios for 14 out of my 19 years in this hobby with no problems.
#6894
hey pauly when when you get to the track!
#6896
Adrian- The schuies will be out in force tomorrow at the Modesto race. Mo is running gas, Witman is running mod, and Dujuan, Rich, John, and myself are running 19 turn. If Schuie had a 12th scale I'm sure someone would be running that as well.
Good luck to the other Schuie guys at the worlds warm up.
#6897
Hi! shubies good luck in the up and comming races. just thought that i would say hi to everyone!
#6899
Mission Speed
I need some speed, I run a Mission in a "sportsman" stlye class, 540 motor only. At the moment I am using the 83t spur with a 37t pinion. I have good speed but once I get in the twisties I lose the pace. Droping the pinion only results in a loss of top speed. I just cant catch the faster guys at this stage, any ideas ?
