Xray XB4 thread
#4801
I'm in the process of putting my new XB4 kit together and I got 3 of the small spacers for the front steering blocks and one of the big ones, instead of 2&2. I bought my kit from A-main, what is my best bet for getting the correct ones sent to me? Call A-main or is there somewhere else that handles those type of issues?
#4803
I don't know about him but I bought the Exotek 12mm rear and 9.5mm B44.2 frt hexes they have made for the XB4 and then run the Evo wheels made for the B44. You can also get the the 12mm frt hexes they make for the XB4 and run Kyosho front Evo wheels.
#4809
#4811
I have a 2014 with about 6 runs on it. It shows no sign of wear except few scuffs on underside of chassis ran only inside. I have front and rear diff cases arms ball cups exotek metal cups installed spare front and rear arms team sr towers to much to list . like 3 sets of tires spare brand new wheels at least $300 worth of parts I will take $425
#4812
I need some help. Last night during my main my car started making an awful racket. Needless to say after a lot of reading in here I thought I was loosing a gear. I kept on pushing on and finished 2nd in the main. Afterwards I took the body off and started snooping around. It is actually my spur gear, and not because of gear mesh. I have a TON of back and forth/side to side play in my slipper setup. What in the world is going on here? Any ideas?
#4813
Sorry if this has been asked before but can anybody tell me an easy way to replace the large pin in the end of the dog bone of the centre shafts on my xb4??
#4814
this is what you will need:
#106000 Hudy drive pin replacement tool
#106051 Hudy drive pins
purchase a small sledge hammer from harbor freight
#4815
really no easy way to replace it unless you have a drive shaft pin removal tool. I tried removing them with an arbor press and only got 1 out
