Xray XB4 thread
#4774
I've got a loud "chirp" coming from my buggy when I hit jumps, likely my spider gears I'm thinking. My drivetrain seems loud. Ya, I land sideways & cartwheel more than even I like.
Are you guys replacing your internal gears with the NT1 steel gears (335030) or the newer 2014 composite gears (304930)? I'm not Martin Bayer or Tyler Vik - what do club racers replace their gears with?
I may have answered my own question.
#4776
#4779
Hi All so finally got my xb4 now waiting for motor and esc to arrive then I'm ready just a question I would like to ask I see some guys are running a savox sc1258 tg servo my question is I own 2 of them so plan was to fit 1 in the xb4 but now I'm thinking won't it go up in smoke cause its running off a lipo saddle pack?
#4780
Funny, when new the Xray was practically silent. Now, it makes a loud "whirr" sound when on the track. I am using the new Spec R front double jointed universals, so I may try switching back to my stock universals to see if that'll quiet'er down.
Update - upon closer inspection - nothing 'seems' broken or out of place. The pinion, 35T bevel, the internal diff gears - all seem ok, no chipped teeth. Hmm. Just because I can't see it, doesn't mean they are ok though does it?
Anyone know when the new aluminum 35T bevel & steel pinion will become available?
#4781
#4782
R/C Tech Elite Member
For the record the only thing I’ve broken so far was the upper deck which was entirely my fault. I’ve had zero problems with my drivetrain so far, I adjust the slipper a bit on the loose side but our track is also mid-bite traction so there isn’t as much stress on it as in high bite conditions.
#4783
Right - I guess loud is relative then, lol.
There's a nice "whirr" and a bad one!
The other two XB4's at my track are whisper quiet in comparison. It might be the spur/pinion however. I had all winter to fix it and lube it so it got done. New parts mixed with this chirping issue make for a slight mystery for now.
#4784
the barking sound is your bevel gear. replace it, lube it, and reset your slipper and it will go away (please read post #4775... lol)
