Like Tree248Likes
Xray XB4 thread
Old 01-26-2014, 09:15 AM
  #3901
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by 1airborne
I run stock springs up front and kyosa white rear. also a 1 dot rear sway bar. Front diff is 5K rear 2K. RR hinge pin holder cups 1 center out. I was still a little loose and then I Loosening the slipper. Now I don't have enough steering. I wish I had a little more. I am still looking and working to get just a little more.
Hope this helps
1airborne
That's where I'm at now 5/2 and rear center out. My slipper is just tight enough to make all the jumps any tighter and it's worse. The lower I go on diff fluids the better it gets but also gets twichier and harder to drive. Going to do some testing this week with different springs.
rcgod is offline
Old 01-26-2014, 11:59 AM
  #3902
Customworksking's Avatar
Trader Rating: 74 (100%+)
Cool ?
Originally Posted by Qwkrn U
M4 ions , new JC dirt webs if you ca get em , scrubs suburbs M4
Gearing 6.5 19t 7.5 20-21t
for the pro-line scrubs I found rear 4wd the only fronts i found say 2.2 2wd part number PRO821603
Customworksking is offline
Old 01-26-2014, 08:14 PM
  #3903
Trader Rating: 44 (100%+)
Anyone looking for a lightly used 2014 ? Love the car just no time for 3 classes
1000rrstunna is offline
Old 01-26-2014, 08:29 PM
  #3904
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
The front 4wd scrubs are no longer being manufactured from my understanding due to the release of the ions. Just a matter of getting lucky and finding a set in stock. Blaze Rc may still have a few sets in stock.
Originally Posted by slakr
XRA335030 is the part number. Finding them in stock is another story.
Fast lane rc track (Blue springs MO) had a few sets in stock I noticed this weekend while I was there. . Not sure if they will ship or not.
Qwkrn U is offline
Old 01-27-2014, 05:32 AM
  #3905
Default Good by guys, thanks for everything
I ran my 22-4 yesterday. It's time to let the XB4 go. Thanks for the memories and good times guys.
losi b is offline
Old 01-27-2014, 09:32 AM
  #3906
Trader Rating: 50 (100%+)
I think I have 50 pairs left of M4 Scrubs. I grabbed a bunch when I heard they were discontinued.
jamesbernatchez is offline
Old 01-27-2014, 09:49 AM
  #3907
seth556's Avatar
Trader Rating: 43 (100%+)
They should be coming out with x3 and x4 scrubs I believe.
seth556 is offline
Old 01-27-2014, 10:04 AM
  #3908
How much are used2013 XB 4'S selling for these days? I cannot get the search function to work for me.
losi b is offline
Old 01-27-2014, 10:53 AM
  #3909
Qwkrn U's Avatar
Then start sharing with your xray family.
Qwkrn U is offline
Old 01-27-2014, 04:32 PM
  #3910
aloksatoor's Avatar
Hey, I am running the following
2014 slipper pads/springs slipper is set pretty loose
5 5 diff
front soft compound rebar rear super soft rebar
1mm rear sway front stock,
durango wheels (the rears are narrow you might be able to replicate with -.75 rear hubs)
2014 xb4 2wd rear hinge pin holders without rear chassis spacer, rear droop 2 turns out on shock bottoms, front full droop 3 dot front 1 dot rear avid pistons of course. Oils 550 F and 350 R.
Hinge pin holders 1 mm offset with hinge pins on the lowest setting RF RR.
Drives like my ebuggy, rear stuck on power with a bit of push, tonnes of steering off power.
aloksatoor is offline
Old 01-27-2014, 07:34 PM
  #3911
seth556's Avatar
I think I've found the 12mm solution, and it's super cheap. Traxxas
Also the wide front hexs in the front and Kyosho front wheels.
seth556 is offline
Old 01-27-2014, 10:24 PM
  #3912
Trader Rating: 23 (100%+)
Sent you a PM
flybyublue is offline
Old 01-29-2014, 06:52 AM
  #3913
subaru_tech's Avatar
Trader Rating: 106 (100%+)
hoping someone has info on this.
i picked up a v2 xb4 a while back but the shocks leak badly.
is there any updated seals that are prefered over the stock seals.
it just seems everyone but kyosho has problems with seals till they come up with some that finally work.
subaru_tech is offline
Old 01-29-2014, 06:54 AM
  #3914
BillyT.'s Avatar
Mine don't leak on my 2014.
BillyT. is offline
Old 01-29-2014, 10:54 AM
  #3915
i see you guys talking about running the avid pistons and drilling them out. Are any of you guys running them stock ? how do they feel stock ?
evolution03 is offline
