Xray T3 2012
#767
#768
either. I'm running the 52s. you can run the 50s, but add a 1mm spacer between the adapter and the axel. running the 50s can cause the adapter to break because the ecs pin is not sitting far enough in the adapter. I went thru countless adapters until i read about this mod of the 1mm spacer, OR you can run the alum adapters and not worry about the plastic adapter breaking
#770
http://sidepieceracing.com/products/nikita/
#771
or you can just buy some serious outdrives instead -- Side Piece Racing Nikita Outdrives
never seen or heard of these before....
look good, if i go back to a spool, i might look into these
#772
I just got a set of nikita outdrives. Running fairly narrow, 1.5 spacers, 52mm ESC drive shafts and still have room in the outdrives to go narrower.
Also the large diameter is less wear and tear on the blades, have two races days on mine and the blades still look new.
Definitely a high quality product.
#773
what is the pinion range people are using for indoor carpet with the stock 84/48 spur and 17.5 blinky. Thanks.
#774
I started with the 700cst too. My friend runs 1000cst and last weekend I tried 2000cst. Works also but I must admit I didnt feel the difference because we were on a different track.
#775
Perhaps you guys need some better quailty tape?
Bb
#776
BUT unless you put exactly the same amount of oil in the diff you may not notice any difference (too much thin oil make it feel thick, too little thick oil makes it feel thin)
Bb
#780
flyingfoxrc.com
