Like Tree1Likes
Xray T3 2012
Old 11-30-2011, 11:34 PM
  #796
Originally Posted by MeBeMikey
I'm on the Xray Team here in the UK. Here's my basic set-up that works well almost everywhere I go:
HPI Pink (f) and Silver (r) springs
Shocks mounted center hole
MuchMore 450 or Associated 37.5 oil
Alum Shocks w/ 1.1mm 3 hole pistons (0 rebound)
Droop 6 f. 5 r.
Kit CVD's. I'm faster with them.
Camber 1.5 all around
1 deg toe out front
3 degree toe in rear
5.2mm ride height
Dif oil 1000 Edit brand
No shims on inner bulks (camber link) 2mm outer front and 4mm outer rear.
Front spool
Sorex 28r tyres and LRP Carpet additive.
To solve any issues with my car I adjust additive timing and might lower front shocks one hole.
For MooreSpeed tyres I run MooreSpeed Red springs and HPI silver rears.
This is pretty much what all us Xray team drivers run in the uk, give or take a couple of things, you never know mikey, I might let you get a littler closer to me at the next round of the winter series
Mb3195 is offline
Old 12-01-2011, 04:04 AM
  #797
Skiddins's Avatar
Originally Posted by auzzy_mate
I have seen a 48p 64tooth spur at my LHS and I have a 48p 42t pinion which would work at getting 2.9FDR, but I just don't know if they would fit and mesh.
Anyone?
Ben
The min tooth sum is 100, maximum is 112, so that combo should fit right in the middle.
But will that spur mount correctly?
Skiddins is offline
Old 12-01-2011, 08:21 AM
  #798
Default springs
How do the xray and hpi springs compare, is one more linear than the other?
What would hpi pink and silver be in xray springs?
Matt W is offline
Old 12-01-2011, 09:06 AM
  #799
they are pretty similar to 3.0/2.9 and 2.6 to be honest. Car just feels a bit better with them on.
Mb3195 is offline
Old 12-01-2011, 03:29 PM
  #800
Skiddins's Avatar
Skiddins is offline
Old 12-01-2011, 04:05 PM
  #801
Droop 6 f. 5 r.
1 deg toe out front
5.2mm ride height
Front spool
Can one of the UK xray team post there full carpet setup please, I would be very interested
FLAT OUT is offline
Old 12-01-2011, 05:37 PM
  #802
theatriks's Avatar
does anyone have the part number for those 2 little black pieces u screw on top of the spur gear bearings i cant find it in the manual
theatriks is offline
Old 12-01-2011, 05:44 PM
  #803
Regional Moderator
CarbonJoe's Avatar
302069 T3 COMPOSITE LAYSHAFT BEARING SUPPORT SHIM (2)
page 9 exploded view
CarbonJoe is offline
Old 12-01-2011, 05:56 PM
  #804
theatriks's Avatar
thanks man brain fart
Old 12-01-2011, 05:57 PM
  #805
Bigz84's Avatar
Trader Rating: 23 (100%+)
Default downstops
where are most people setting their stops at, on carpet, w/ Sweeps, med bite? I'm at 6F, 5R, running 5mm ride height in front, 5.5 in rear. I was just wondering if i should go higher or lower. I have never measured the droop, by ABR (above ride height), but i see it alot on xray setup sheets.
Bigz84 is offline
Old 12-02-2011, 12:22 AM
  #806
http://forum.teamxray.com/xform/inde...=t3_2012&ID=51
Here you go mate, if I need more back end I tend to lower my rear pins slightly. I also run my shocks in one hole front and back when running moorespeed tyres.
Mb3195 is offline
Old 12-02-2011, 01:28 AM
  #807
piper48
Guest
Posts: n/a
Default 2011 vs 2012
I'm in the market for a new TC and was just curious to know what the difference is between the 2011 and the 2012.
Old 12-02-2011, 01:43 AM
  #808
According to Xray everything in the 12 has been "optomised"
But the real difference is a new top and bottom chassis that has more flex and gives more grip. There are a few other upgrades, east-west servo, new roll centres and new shock positions but thats about it.
Bb
bucketboy is offline
Old 12-02-2011, 04:16 AM
  #809
morgoth's Avatar
Anyone?
Ben
You'll need a 64p pinion too.
morgoth is offline
Old 12-02-2011, 08:58 AM
  #810
M-Technic's Avatar
Trader Rating: 15 (100%+)
I'm in a bit of a pickle as far as the balance of my car goes. My batteries are quite heavy, and even with large/heavy ESC, motor fan, etc., I have to add almost 50 grams of weight to the electronic's side of the car to get it to balance left-right. I end up way over our weight limit of 1380g, by 40-50 grams IIRC.
Would it make any difference at all if I were to flip the drive train configuration to the NiMH configuration with the belts flipped? I'm afraid it won't make much difference at all, since it doesn't actually transfer much (if any) weight in and of itself.
I'm just thinking of ways that I can balance the chassis without having to add so much weight to the car.
M-Technic is offline
