Like Tree387Likes
JConcepts Thread
Old 07-21-2008, 04:44 PM
  #2011
Nice D4 body........Way to tease us (look but don't touch) with those BarCodes!!
MustGoFaster is offline
Old 07-21-2008, 05:52 PM
  #2012
PW
PW's Avatar
The rear Bar Codes are already available; but not the fronts
PW is offline
Old 07-21-2008, 08:45 PM
  #2013
pq49z's Avatar
actually those fronts look like losi taper pins
pq49z is offline
Old 07-21-2008, 11:19 PM
  #2014
tom_chang79's Avatar
Trader Rating: 13 (100%+)
Is it just me, or does the "Scoopless" body for the B44/BJ4WE "puff" outwards more towards the front?
I'm actually looking for a body for my BJ4WE that "puff" outwards more towards the front cause I'm planning to stick a motor cooling fan. Currently, the default BJ4WE narrows up too much (although the default BJ4WE body is a beauty )
Is the Scoopless body more friendly for a motor fan placed above the endbell? For say, a 30x30mm fan?
tom_chang79 is offline
Old 07-22-2008, 05:39 AM
  #2015
PW
PW's Avatar
Actually there not
We did add extra clearance to the existing front scoopes, but not enough room to add a fan on top of the motor. Some people run the fans on the chassis blowing onto the motor. Most top racers just cut the front of the body out more and don't run a fan.
PW is offline
Old 07-22-2008, 08:07 AM
  #2016
Thanks, that's what I was planning to do, prop up a fan so that it's blowing into the endbell... I think if that proves to be troublesome (such as the fan not holding up), I'm going to try the other method, carving out a hole in the body. Do you pro guys glue a small screen material to block out the large chunk of dirt? I'm thinking an old nylon stockings?
Old 07-22-2008, 11:16 AM
  #2017
Are those the Bar Code front tires? Because those fronts look nothing like the Bar Code rears. I was hoping that J Concepts was gonna make Bar Code fronts that have the same tread pattern as the rear. What they need to do is make rears that have the same tread pattern as those fronts to use on "taper pin tracks" I thought the only reason everyone runs the BK Bar rear Taper Pin front combo was because losi didn't make BK Bar fronts. I thought J Concepts was an "outside the box" company? Now, if they did testing and found that front tires with a "Bar Code" pattern just didn't work and the "tapered pin" design did, then I retract my previous statment.
ifuonlyknew is offline
Old 07-22-2008, 01:59 PM
  #2018
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
BK Bar fronts.. don't work. I've tried them...
Frank Root is offline
Old 07-22-2008, 08:07 PM
  #2019
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Timmmmmm AYYY!
lol
Thanks Andrew!
I am painting up a crawler body to see what can be done with one, so i'll psot that as soon as it's complete! (By the weekend maybe?)
...Jim
W.E.D.
W.E.D.Jim is offline
Old 07-23-2008, 08:17 AM
  #2020
AndyMoore's Avatar
Trader Rating: 64 (100%+)
The Clash is ON for 2008!
www.rcclash.com
Online signup is now LIVE!
http://www.rcclash.com/signup/index.asp
AndyMoore is offline
Old 07-23-2008, 09:01 AM
  #2021
How to post a question on RCTech.
1. Ask a question.
"Are those the Bar Code front tires?"
2. Answer your own question.
"Because those fronts look nothing like the Bar Code rears."
3. Offer an "expert" opinion on "what they NEED to do"
"What they need to do is make rears that have the same tread pattern as those fronts to use on "taper pin tracks"
4. Question your own expertise.
"I thought the only reason everyone runs the BK Bar rear Taper Pin front combo was because losi didn't make BK Bar fronts."
5. Question the expertise of a multiple IFMAR and ROAR Championship winning manufacturer.
" I thought J Concepts was an "outside the box" company?"
6. Question your own expertise again, and nearly admit that you have no idea what you are talking about, have no experience or knowledge in the arena of tire carcass/tread design or development, and have no racing or testing experience to substantiate any claims previously set forth in your poorly phrased and semi-grammatically incorrect post.
"Now, if they did testing and found that front tires with a "Bar Code" pattern just didn't work and the "tapered pin" design did, then I retract my previous statement.
Awesome post man.
SirSpeedy is offline
Old 07-23-2008, 01:12 PM
  #2022
Old 07-23-2008, 01:33 PM
  #2023
Trader Rating: 32 (100%+)
www.rcclash.com
South Florida in December....lI may have to think about that.
I need to see if Shue is going again.
JD
JDCrow is offline
Old 07-23-2008, 07:22 PM
  #2024
W.E.D.Jim's Avatar
LOL
...Jim
Old 07-24-2008, 07:57 AM
  #2025
FYI to all.
I found this useful link off google:
http://www.rctech.net/articles/paint...ntedmyst.shtml
Not sure why I couldn't find this link off of rctech.net. Perhaps it's some page that the admin have abandoned? Nevertheless, it's a useful page full of info and tips on how to paint RC Bodies.
I remember seeing an article like this in RC Car Action about 15 years ago. Man, I wish I kept that issue. The author went in detail of how to do some really nice effects with just rudimentary tools and supplies.
Thank god for internal decals and masks from XXX main for body-painting-challenged people like me!
