Tamiya TRF418
#2057
Will the 419 gear diff fit in the 418? What is the difference between the two gear diff sets?
#2058
the differences are;
- larger oil volume
- more coarse internal gears (different ratio of planetary to spider)
- different material for internal gears ("smoother" plastic)
- symmetrical outdrives
- bushing/bearing for outdrives, not relying on casing only
- case screws take a normal 1.5mm hex!!
- its black
- they leak more easily. have to be much more precise when building.
#2059
yes it will fit.
- larger oil volume
- its black
- larger oil volume
- its black
#2060
I just acquired a used TRF418 and have been going over the chassis to check bearings, settings, etc to be sure it's ready to race. This will be my 17.5 blinky chassis and I'm hoping for good things.
One area has me puzzled, the lipo battery retention. The stock kit uses bolts with spacers to keep the lipo clear of the belts in the middle and plastic forward and aft blocks to keep it from moving front to back.
What I don't see is anything that keeps the lipo from sliding out the side of the chassis. All of my other sedans have had L shaped plastic or graphite pieces that keep the lipo on the chassis, but this one has nothing. Am I supposed to reply on the battery tape for this?
#2061
I would strongly recommend disposing of the kit chassis as soon as you get the chance. I switched to Samix carbon and the car was massively improved. It also has a more conventional battery mounting system, if such things are important to you!
#2062
Trader Rating: 38 (100%+)
Samix has those battery tabs. It comes with their carbon fiber chassis upgrade.
#2063
The tape is more than sufficient to hold the battery in. Never had any issues with the tape - had more issues with the servo mounts/screws obscuring the tape slots.
#2064
http://www.rcsamix.com/index.php/for...version-2.html
$59.99 + your choice of shipping.
Goodluck!
#2065
Sir have a look at this.
Goodluck!
Goodluck!
#2066
Goodluck!
Goodluck!
#2067
Since you have noticed a huge improvement I would like to know if this is on asphalt or on indoor carpet?
#2068
Is the chassis alone going do the trick or do I need to get the whole conversion kit? I have 2 418 running blinky 17.5 and mod 5.5. My mod car doesn't handle too bad, but my stock car is struggling with corner speed since I moved from my 417's. I have been running Tamiya for quite sometime and currently debating to try an Awesomatix in stock.
http://kentech.blogs.se/2014/04/25/s...-kit-18305523/
And here's another review:
https://fiveeight0sixsix.wordpress.c...tamiya-trf418/
And here:
http://www.rctech.net/forum/electric...trf418-92.html
#2069
For the longest time I have debated whether or not to get the Samix carbon chassis. From what I've been told, the stock chassis is better if I'm racing on high grip carpet in 17.5 or 21.5 blinky because it's stiffer and won't flex as much.
I know there is a lot of talk about how a stiff chassis is better on high grip however I have yet to see any real evidence for this, certainly on rubber tyres. Most of the racers I know couldn't cope with the aluminium chassis when they were trendy and went back to carbon soon enough.
