Like Tree2Likes
Tamiya TRF418
Old 02-09-2015, 11:06 AM
  #2026
Trader Rating: 32 (100%+)
Originally Posted by Gordie88
I run with all top deck screws. The added flex MADE THE CAR COME ALIVE FRONT AND REAR!!
I will most likely take away some rear traction this weekend aswell....
and also play with shims to get the front end to not be so aggressive but keep the amount of steering i have...
Tried the new Dart and it is a bit better for me but i still think 17.5 T LTC is where it is....
Hey Gordie,
Are you running Carpet or Asphalt?
- JV
ittjv is offline
Old 02-09-2015, 06:43 PM
  #2027
CRC Carpet.. Sorex tires.. Sometimes Gravity RC C tire..
Gordie88 is offline
Old 02-16-2015, 11:20 AM
  #2028
Just finished the Ontario Triple crown series..!!
The Samix carbon v2 chassis felt really good. It adapted to the traction change as th weekend went on. The small changes kept the car consistant for me !
Took the overall Series Win 17.5t blinky . Going to race the same setup i have in 13.5t blink and see if it can handle more power...
Gordie88 is offline
Old 02-16-2015, 11:49 AM
  #2029
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
Default Chassis
how different would the Samix v2 carbon chassis be compared to the Aluminum one?
I'm super happy with my alu chassis on asphalt but it's a tiny amount bent now, considering experimenting with a soft carbon chassis now. Not too sure how much the slight bend affects handling but if I push the rear end down, the front moves up maybe 2mm
lagcisco is offline
Old 02-16-2015, 03:00 PM
  #2030
in theory it will be completly different.
I havent tried it back to back on 418... but on the 419 i felt the alum was far more stable but had a slight push...
I would think the Saxim Carbon would give you a more aggressive front end so you may need to adjust setup for the chasssis...
RCmart has them in stock or check them on facebook I love the floating spur mount for stock racing,,
Gordie88 is offline
Old 02-16-2015, 03:28 PM
  #2031
I ordered a Samix aluminum chassis to try on carpet. I thought the carbon chassis'ed 418 was pretty decent on carpet, but a little subpar on asphalt. Heck, the aluminum chassis feels like it has more flex than the stock carbon chassis. I would think a softer chassis would help the car on asphalt, like Gordie says. We'll see how it goes on the rug with the aluminum one...
- JV
ittjv is offline
Old 02-16-2015, 04:21 PM
  #2032
I pretty much just run stock setup with alu chassis and front diff with 2.5million on asphalt. Gained traction and some turn in steering which is quite helpful especially on a hairpin right after the straight
lagcisco is offline
Old 02-16-2015, 06:06 PM
  #2033
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
The Samix conversion helped me slightly in the lower grip asphalt that we run versus stock carbon. This is only 17.5 racing though. I'd imagine for mod, the difference would be much bigger (and more positive).
Dan is offline
Old 02-18-2015, 11:33 AM
  #2034
I happen to have some roche dcjs 45.5 lying a around.. would it be of any use to run these in the rear? my stock alu driveshafts have some slop in them now.
also, how is the quality of STRC titanium screws? I have a set for another car I thought about donating to this car.
lagcisco is offline
Old 02-25-2015, 12:04 PM
  #2035
bagged69chevy's Avatar
Trader Rating: 22 (100%+)
very clean trf418 for sale, if anyone is interested
http://www.rctech.net/forum/r-c-item...ya-roller.html
bagged69chevy is offline
Old 03-03-2015, 09:02 AM
  #2036
jdawg81's Avatar
If i'm racing in onlyl 17.5 or 21.5 blinky, would there be any performance improvement in switching to a Samix graphite Version 2 chassis conversion kit? Or am I better off leaving it as is with the stiffer Tamiya chassis?
jdawg81 is offline
Old 03-03-2015, 09:41 AM
  #2037
Dan
Dan's Avatar
What surface are you running on? Carpet, asphalt? Low or high traction?
Dan is offline
Old 03-03-2015, 09:45 AM
  #2038
jdawg81's Avatar
I race indoors on med to high grip carpet.
jdawg81 is offline
Old 03-03-2015, 09:47 AM
  #2039
Dan
Dan's Avatar
I'd stick with the stock chassis on carpet, as stiffer is more desired when traction is higher.
Dan is offline
Old 03-04-2015, 06:18 AM
  #2040
I had the same thought that the stiffer chassis would be better then the Flex carbon from Samix... BUT...
I am a believer that the car gained overall traction and changes i made to the car were more noticable...
So for me Samix Carbon stays on the car... even at high traction!
Gordie88 is offline
