NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#1487
#1488
Its worth a try.
#1489
the catman, are you using corally plugs, if so check to see if they are a tight fit, if they are loose a bit arching will occur and generate heat causing the solder to melt.
#1490
#1494
I had a problem last year with a sensor lead having 2 wires swapped around on one of the plugs. it caused the motor to get very hot and also it wouldnt run from standstill only when turned. This has made me get into the habit to always check the sensor leads.
#1495
moved
#1496
in need of oomph
help me
I set my speedo up, and found that it lacks low down and mid range punch. I have the 518 software on my xerun 120a and am running 13.5 my ration if 6.1 - 6.3. I am running it indoors, and need the profile for a 30 metre long straight. The top end seems reasonable, but i am being outgunned in low to mid.
can someone be kind enough to post their profile please?
#1498
help me
#1500
help me
