Rody VS Racing Engines - Onroad Motors
#346
VS_Rody
i have a stupid question, are those cylinder and piston sets inter-usable
1. euro in euro 2 crankcase
1.1 euro in shimo 2 crank case
2 euro 2 in euro crank case
2.2 euro 2 in shimo crank case
3 shimo 2 in euro crank case
4. shimo2 in euro 2 crank case
5. 2104 in shimo 2 crank case
6. 2104 in euro 2 crank case
7. 2104 in euro crank case
wonder if anyone has this info? cheers
#347
VS_Rody
The Shimo2 and Euro2 have some extra lubrification porting for which you need the Shimo2 crankcase(which is the same for the Euro2).
Hope this has cleared things for you.
#348
I was told the Hasi has a slight different diameter sleeves and so parts are not interchangeable.
#349
I do not think OS does this, unless the qty's Hasi takes are very important which I doubt. But since I do not know for sure maybe somebody who has a Hasi measures the outside diameter of the sleeve and so we can clear this.
#350
A friend who is doing some OS (based) engines had several models side by side and he did notice that, maybe more like a tolerance thing.
#352
1. then may i use euro 2 or shimo 2 cylinder piston set in some models with inner head without inner o-ring?
2. with that said, i can just pick to buy either euro2/shimo2 for euro2/shimon2 crankcase
3. how about euro2/shimo2 cp set into 2104 (even the crankcase has no lubrication trim inside)?
thanks so much, you are appreciated
#354
ok, thanks
2) Yes, you can also buy the Shimo2 or Euro2 crankcase.
3) Yes you can but the extra oil ports will not be of any use.
#356
If you speak about the o-ring in between the crankcase and the underhead, this also you can use with out without on any R21 type crankcase.
#357
The extra cooling/lubrication holes can be made to work with grinding some slots in the sleeve.
I have made even some of those ports on my 5 port R21
