Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Rody VS Racing Engines - Onroad Motors >
Like Tree137Likes
Old 01-26-2022, 07:34 AM
  #316
R/C Tech Elite Member
VS_Rody's Avatar
Originally Posted by BigC2007
Rody is this a good pipe set to run on a OS R2104 ? >>>>
VS Racing EFRA 2098 Tuned Pipe Combo w/MR02 On-Road Manifold.
Sorry not to have been around for some time.
Yes, this combo works well on the OSR2104
VS_Rody is offline
Old 01-26-2022, 07:44 AM
  #317
BigC2007's Avatar
No worries and thanks Rody I will order one
VS_Rody likes this.
BigC2007 is offline
Old 02-01-2022, 09:19 AM
  #318
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Rody, is Amain not carrying VS anymore?
1/8 IC Fan is offline
Old 02-01-2022, 09:41 AM
  #319
VS_Rody's Avatar
They have been selling mainly our off-road engines but sales have not been really high and the interest for our line seems not high enough for them to maintain the line.
I will make contact with them.
VS_Rody is offline
Old 02-01-2022, 11:38 AM
  #320
Roelof's Avatar
Rody, do you have an answer on my question regarding shimming?
If with the new 12~13% nitro fuels (16% by weight) you can remove the 0.15 shim instead of the 0.1mm shim to run the normal old 16%
Roelof is offline
Old 02-01-2022, 12:32 PM
  #321
VS_Rody's Avatar
To be honest, I have not made any test with this kind of nitro % yet.
For sure the 0.15 can be something to try when using an official produced 16% by weight fuel. But until now I have not been able to find this.
In France we just got the news that the nitro rule has been pushed for one year, so we are good for 2022
VS_Rody is offline
Old 02-01-2022, 01:42 PM
  #322
Roelof's Avatar
That is good to hear that Frans is not in a hurry to make a direct change. I still have about 10 liter of fthe old 16% uel and it seems the Netherlands and Belgium is forcing the new fuel because the new Nitromax is on its way. Also the upcoming EC40+ need to be run with the new fuel.
I will mix some methanol and castor oil to nitro less fuel to mix it up with my fuels to 13%, I have heard the Italians run 13.5% nitro that stays just within the maximum determined weight of gravity.
There is a high chance this year I will swap to OS, I am running my last Novarossi engines, thats why.
Roelof is offline
Old 02-01-2022, 11:51 PM
  #323
VS_Rody's Avatar
I have understood that the nitro law was mainly restricted for the one's who are selling the fuel.
Anyway, it is stil not very clear how this restriction can be settled or put in place while there are still discussions going on between the gouvernements and the RC associations who are inflicted by this.
And as you can see, there is no real way to control the real % of nitro in the fuel as actually some manufacturers are playing with specific low density oils and which make this thing even more complicated. At the end all this is not really good for our sport.
If your upcoming event has to be run with this new rule, then some manufacturer has to start and produce the allowed mixture and make it available to everybody! Also the so called new Nit.roMax has to be available too
VS_Rody is offline
Old 02-02-2022, 01:35 AM
  #324
Roelof's Avatar
Yeah, true, but w/o selling higher content nitro or pure nitro no user should be able to use it as well unless the user has a licence to get pure nitro.
The new Nitromax seems to come from Capricorn and is ready to ship so it is on time when the season starts.
And yes, I did try to get some Runnertime Ultra (16% acting as 25%) but nowhere to get so I am afraid this "secret" fuel is not for everyone to get and does fool other drivers. Indeed just checking the weight does not tell a thin about the nitro content as in the past with the 25% rule it was easy to run up to 32% on hot days.
Roelof is offline
Old 02-02-2022, 08:28 AM
  #325
Rick Vessell's Avatar
Rody,
Any thoughts on fuel with zero nitro content? Just methanol and oil? It would be less power for sure but it would avoid the nitro content issue completely. Engines have run on straight methanol in the past, particularly in airplanes.
Rick Vessell is offline
Old 02-02-2022, 09:05 AM
  #326
VS_Rody's Avatar
Originally Posted by Rick Vessell
Rody,
0% nitro works on airplane engines but very hard to make this work on car engines. Main problem is the idle. It becomes very hard to keep the engines going at low rpm.
Rick Vessell likes this.
VS_Rody is offline
Old 02-03-2022, 06:08 AM
  #327
invrtd's Avatar
Trader Rating: 29 (100%+)
Have you been seeing a quality issue with the current OS engine parts and engines you have been receiving? Break in on new OS engines is not the same. They have always broken in a little faster then nova, but now there is almost no break in time required. Pinch seems to be almost non existent on new motors? I know OS is busy trying to keep up with demand, but hope they aren't cutting corners on QA checks.
invrtd is offline
Old 02-03-2022, 08:08 AM
  #328
VS_Rody's Avatar
For me the quality of OS has been has always been excellent and less fluctuating compared to the other brands. I also noticed that the OS engines do not always have great pinch but stil they run excellent and have great performance. Of course there is also some fluctuation in the engine production of OS but for me less then the others today.
Rick Vessell and davidl like this.
VS_Rody is offline
Old 02-03-2022, 09:22 AM
  #329
Roelof's Avatar
Could it be that they have learned from the difficult break in issues of the 2104 and so changed the starting pinch?
Roelof is offline
Old 02-03-2022, 09:51 AM
  #330
VS_Rody's Avatar
Never had this issue, just started working with them in 2014.
nitrodude likes this.
VS_Rody is offline
