Serpent 710
Originally posted by spawn
you running one-way this saturday?
Originally posted by markp27
I will have to do some timed laps to compare the solid with the one-way, as I fear that with the solid, it may appear faster, but may turn out to be slower
Originally posted by InitialD
Yeah... Don't worry. I guess it's how consistant you can go around the track. But don't get too much influenced by that Slow&Steady thingy... Does not work.
Cheers, Mark.
I'll have to get myself a front diff, I think.
Originally posted by crashed_1
You mean you've not armed yourself with one of the darkest secrets of racing?...
Re: Re: Gear Diff
Calvin, Mark is correct. Only ball diff is available. Why do you need a gear diff when you need to mess around with the diff lube when you can tune the ball diff to infinite possibilities on the track without taking off the diff?
And no, the ball diff is pretty bullet proof. Not like some other cars where the diffs will wear out very fast. This is because the ball diffs on the 710 does not use pressure of the balls on the plates to set the diff tightness but rather rely on a plastic clamp system to set the diff tightness. I still have the same rear ball diffs and plates after close to 11 months of usage.
If you have any question, please do not be afraid to shoot.
Originally posted by baller360
does anyone have pictures of there serpent 710 with the lola bumper on it i would like to see some pictures PLEASE!
Knock yourself out!...
Real men don't do diffs Ehm, well not yet, anyway
Finally got the 710 and I need to ask a question about assembly. On the rear diff assembly the big c clip is supposed to lock the thrust bearings into place right? In other words I should compress the clip until it snaps into place inside the outdrive, right? Page 9 step 2.3 just for reference. Thanks.
BTW, congrats on the new car.
XER987, make sure the conical washer and the thrust bearing (the 2 plates with different inner diameter) is installed correctly as per the manual.
Thanks...I'll probably be checking back for other tips...all help is very appreciated.
Re: Gear Diff
Originally posted by calvinchan
Hi ! I'm new to 710. Any one know that 710 Ball Diff change to Gear Diff, possible?
Looking forward to your reply.
Regards,
Calvin
Regards,
Calvin
