Serpent 710
710 upgrades for next season?
Anyone knows what improvements/minor upgrades Serpent planned for the next cold and dark Winter months? Heard something about improvement of rear arms but am not sure....
Originally posted by redsand
hey rif, when will the blackbook rev5 finally come out ?
this morning i went to a machinist to drill a 3mm hole on the left side of the chassis (just a tad in front of the mid pulley mount) to install a 20 gram of ballast.
Should be more than 20 grams bro.. at least 45-50 grams if you were using FP-S9550 as steering servo.
With 60 grams it would change your car handling.. better direction.
Pyramid notes that the alu. mid pulley mount is way higher than plastic one so front belt would not scrub chasis anymore.
OK...it still (Rev3)...confirmed
OK, here a photo that i would like to share...hmmm, nice eh
the power of Serpent...the bigger the better!!
Originally posted by GoldFinger
For the next rev till 5 we still trying to find perfect rear bevel diff set.
Pyramid notes that the alu. mid pulley mount is way higher than plastic one so front belt would not scrub chasis anymore. [/B]
I told him to let me know once it becomes available.
Speaking of the servo, I'm using the Sanwa WRX for steering. Do you think 20 grams of ballast is enough to counterweight ?
your 950r is quite comparable with the centerfold playmates...it is turning me on !!!
No more ball diff ??
Called Sur at JITC last Sunday, the new mid pulley mount was back ordered though.
As for WRX, I think another 100grs will make it perfect balance
Originally posted by Pyramid
Hi Om Redsand, looks like there isn`t one diff from other car that is suitable to be used on S710 unless we making the whole new one which is beyond our limits (otherwise we will just make a whole new car ).
One hour from now, all you need will be in Goldfinger office.. force him to sent you direct
have you considered the impulse street-spec bevel diff ?
heheh lol yeah if he wants to send it direct to me, i'd wire the cash rightaway.
pyramid, wait a minute...100 grams to counterweight ??? are you sure ??
Once we got perfect sunsine to take a picture, we`ll sent you pics of rev5 and try to spot the different gives us couple of days.
Re: 710 upgrades for next season?
Hi there,
Hi there,
