Kyosho VoneR Thread
#646
Originally posted by adelmundo
Hello people...I just bought the V-ONE R cooling fan for my car ($29 at my LHS). Going to put it on and see how it looks...pics to follow...
my 2 cents.
#647
Originally posted by Novarossi
Opel, It really depends on the track, Is it a fairly large fast track?
I only ever use swaybars when I want my car to handle 'flatter'. For example, when going through a s-bend, pay particular attention on how flat you car takes it.
I've seen the Kyosho ARB, these things are huge compared to the Mugen ones
#648
Another piont that i found very interesting was that the kyosho rubber setup sheet seemed to work very well, yet the foam setup not as well....... any thoughts? I was thinking that the heat may be starting to play a part in the deterioration of the traction of the foams...
#649
BTW, what's the temp down under at this time of the year?
#650
What do you guys think of the combination of the kawahara diff in rear with kyosho lsd in front?
#651
Originally posted by Manticore
Sorry adelmundo, I wont consider this hop up as this will seize some of the power from your engine. If you have good air flow from outside body shell into inside body shell, you really dont need this thing. If you do not have good air flow from outside of the body shell, you are just circulating warm/hot air inside the body shell.
my 2 cents.
my 2 cents.
Another View:
#653
Re: Roll bars
Originally posted by sparksy
Hey I just got the K factory handshake type front rollbar. It a nice bit ok kit. It seems to work a lot better than the kyosho one. doesn't add to the spring rate. I'll give it a wurl in a day or so...
#654
Re: Roll bars
#655
What do you mean "tilt adjustable" You roll the bar to adjust the stiffness. From what I can see of them they look like they are.
#656
what i mean is the balance between left to right. on the other car there is an eccentric collar so that you can make the adjustment to balance left/right.
#657
What car do they come on?? I have never heard of that before but it sounds cool.
#658
#659
Originally posted by kyosho
The rr version is about $300 us dollars.
http://super.fureai.or.jp/%7Ehoutoku...1/index03.html
