Kyosho V-ONE RRR Evo
#2356
You don't need either, but both have their benefits. Of course the light drive train helps with power transfer and acceleration. The lightweight upper screws help lower the center of gravity.
The lightweight drivetrain parts from Ybslowinc.com will be available very very soon.
#2357
#2359
Front Diff
Last night at the races I tried to install a front diff and had no luck at all. So I stuck with a front spool instead. Does anyone have any tips on installing a front diff. Ive read that you have to change the ackerman to the #11, but some guys at my track didn't change anything. Any tips would be appreciated.
#2360
When i used an diff i just took the one way out and the diff in. didn't had to change the ackerman.
#2361
Location: Cebu City, Philippines and Ocala, Florida, USA
#2362
#2365
#2366
#2367
k factory brake disk
would this fit the RRR EVO???
part no. K1443
part no. K1443
#2368
I need a chasis that is less flexable then the WC 3mm Both cars are almost the same few difference but the chasis looks the same. I have thought of making my own out of 4.5mm 7076 or even 5.5mm. but it might be easier to buy what the pro's use so I can be a better rc guy
