NEW XRAY T2
#2042
Ok,
So I guess I'm a little lucky cause I have two kits.
to make sure, we are saying the problem is in the hub?
Nick
Nick
#2043
Originally Posted by JohnMatrix
Ok,
Nick
Nick
BTW-My way of checking rear toe. I have seen Mike Dumas and Mark Smyka checking it the same way. It does work and is accurate. Everybody is entitled to there own opinion I guess..
#2045
Can anyone tell a good lowprofile servo @ atleast .08?
#2049
It depends on what you are used to....some find servos like the KO 2123 to be perfect at .06....I found it to be a bit much for me....
I'm currently using a 9350, which is only .12 and it's working nicely for me...
The 9550 is the only low-pro high speed digital on the market that I'm aware of...until then ew KO arrives...
#2050
Originally Posted by Anthony.L
dude, it's more then enough. I run my dual rate down because it's way too fast.
Dual rate doesn't control servo speed.
Plus the guy's looking for something at least .08 not just good enough.
I've also heard KO is coming out with a low profile servo. Not sure of the specs.
#2051
Fred... PM on HT.
#2053
#2054
Originally Posted by John Warner
What then does it control??
Fred... PM on HT.
Fred... PM on HT.
This is one of the most key elements to tuning your steering characteristics based on the track(s) you run on.....You usually want to set this by having set full "locked" for the most "tightest" or technical turn on the track you are running on....and this will always vary (day to day) especially on "outdoor" tracks where the weather plays a key role in "traction" on the racing surface....
or at least that's how I set mine...
just my .02..........
#2055
Originally Posted by ghoppa
it controls the amout of wheel movement (left to right) you have based on "lock to lock" (full turn left to full turn right) it usually is rated by the lower the number, the less travel & vise versa.....
