Team Associated TC6.2 Touring Car
#391
I always felt..Lower was always better feeling and smoother to drive for Spec classes ..Mod is a diffrent story same with body style choice.. Look at some A main photos from the bigger races you will see almost all are cut low as can be as per rules..Years ago before the rules were more looked at the "Slammed" body was the ticket.
#393
White? You need to go back to Pink or Red! hehe
#394
What's your time worth to you.
Just getting back into racing and looking to pic up the TC6.2. I see a lot of used 6.1's and plan to mainly do club racing VTA or 17.5 class. I was also looking at the Xray t4-14 but it seems a but pricey and this car looks fantastic from what I've read on here so far.
Is it better to just spend a bit more for the 6.2 or pick up a used older model?
You will spend just as much or more time setting up and old car as you will a new one. I look at it this way, I spend as much time tinkering and paint bodies, cleaning replacing worn parts etc. and for the amount of track time I get in return I want to have as much competitive fun as I can. That being said you can still have lots of fun with a car that is season or two old. And lots of people where you race will know how to get them to work well at the local track.
So you got lots of money by new. Want to get in on a budget get good second hand.. Buy good radio gear and you will always keep it. The car kit is only a portion of you spend ..
Hope this helps..
Steve
#395
I decided to go with a new kit as part of the fun for me is the build process. I ended up picking on up on towerhobbies for a decent price using a coupon code.
Thanks! Can't wait to get the car and have it out on the track!
#397
hi, yesterday my kit came in, so i begin to build.
So far only little problem are the arms between the alu armmounths. they lock a little bit.
So i scrape the arms .1mm, so now the are loose but without slope.
i have already the new RSD springsets all around 13lb,14lb,15lb.
this evening will do some training at indoor track with my B44.2, tomorrow i build further and wil make some photo's
gtz
Sven
gtz
Sven
#398
I can only commwnt on my car because no one else has stated they have had the same issues if you run the front inner camber link without any shims under It you might have to trim he 5Mm to a 3.5mm ish ball stud my rear diff rubbed on my rear shock tower with a shim on each side of the diff so I put both on thr left side to push it out the shocks are just as easy to build as the 6.1 they feel more consistent now my screws that went into my steering rack kept coming lose with lock tight on them so I put a longer one with a nut on it you will probably need a servo saver unless you dont hit walls and the usual battery tray slop but some servo tape fixed that no problem but he car is phenomal much better than my 6.1
#399
I have had great results with the 6.2. It is very consistent and carries excellent corner speed. In comparison to my TC6.1, WHICH AIN'T NO SLOUCH, I'm 3/10th faster and my deviations have been as low as 0.5 at 33 laps. Drivers that are considered faster than me, don't seem as fast any more and I'm challenging for position every time we race.
#402
See you at the track..
#403
#404
The gear diff is very easy to build and have no tendencies of leaking. I have been using them since the first TC6 and have had them filled with everything from 30wt shock oil to 2.5 million wt different oil. The kit setup is a spool up front with a gear diff with 40wt shock oil in the rear. The V3 shocks are great. Very easy to build and very smooth out the box. I look forward to the release of the DCJ 'S for this car to see if I can squeeze some more out of this car.
-Mike
