Hot Bodies Cyclone
#3916
Hey Marcos.J and Protc3, what pinion and spur are you guys running with the 4.5R?
#3917
The Evicerator
I would recommend starting out with a 26 or 27 pinion and a 108 spur
#3918
anyone know where you can get the UK setup sheets plz ?
#3919
There are quite a few on the mirage racing site,if you find the race reports most of thm have the drivers set up avalible towards the bottom of the page.
L8rs
L8rs
#3920
#3921
The Evicerator
#3922
Originally Posted by JoeyE
I talked with Hara about gluing chassis a couple months back. Aside from what is shown on the website, he told me an easy way to do it and it will come out like glass. He said you prep or sand it anyway you want. Clean it with alcohol, drop a thin coat and let it run around the chassis(do not use a Q-tip), then spray any kind of kicker right away. He said to do this three times and it will come out like glass.
Here is my results.
Here is my results.
#3923
http://www.rcedge.dk/Setups/Cyclone/...ERACTIVE-1.pdf
As you can see it is a interactive PDF setup sheet but you can't save your setup unless you have Adobe pro. ,
but you can print it .
#3925
Originally Posted by EvilDriver
JoeyE, when you said spray.. what exactly did you meant by it ? spray it with air or spray it with brake cleaner.. ?
No he means to spray it with a kicker, I think brake or motor cleaner will work but might turn the chassie white! They sell stuff called kicked, its just a super glue insta dry thing
#3926
Here is my results.
Here is my results.
#3927
My Hara Cyclone. Beautiful
#3928
now according to the Hara's guide he uses a Primer to prep the surface after cleaning it.. any one knows anything about it ?
#3930
wow its realy dissappointing that HB didnt take the time to fix the right side middle bulkhead
