Hot Bodies Cyclone
tamiya legacy b4, sorex 36r pre-mounts, track temps around 110 degrees. Car is easy to drive smooth and never loose. Med grip track. I like to dive into the corners but the car atm tends to push. Is there a setup change for me to create a little more over steer?
Front
pink springs
40wt AE oil
4 position on front tower
outside hole on front pro4 arm
1.4 front sway bar
1.5 front block
droop 2mm on blocks
1.0mm under all front suspension blocks.
4mm ackerm
3mm spacer under front camber tie rod
2 of camber
5.5mm ride height
Rear
silver springs
40wt AE oil
#2 pistons
4 on the shock tower
middle hole on old pro 4 arm
1.2 rear sway bar
3.0 rear block
droop 3-3.5mm
1.5 mm shims under all suspension blocks.
rear hub spacers 0.75 in front 2.0 in rear
2mm spacer under rear camber tie rod
arms all the way back (spacers in front of arms)
2 degrees of camber
6mm ride height
Front
pink springs
40wt AE oil
1.4 front sway bar
1.5 front block
droop 2mm on blocks
4mm ackerm
2 of camber
5.5mm ride height
Rear
silver springs
40wt AE oil
#2 pistons
1.2 rear sway bar
3.0 rear block
droop 3-3.5mm
2 degrees of camber
6mm ride height
Also I have heard that there is a Losi MIP CVDs which fit the cyclone.. is this correct?
Cheers
That would help if you could give us a bit more track info. but here are my suggestions to try...
Front
pink springs
40wt AE oil
4 position on front tower Try #3 on the tower
1.4 front sway bar
1.5 front block Try 2.5 deg block it should give you more initial turn in better
droop 2mm on blocks
1.0mm under all front suspension blocks. Go up to 1.5mm to get quicker responce
4mm ackerm
3mm spacer under front camber tie rod Try start with 2.0mm
2 of camber
5.5mm ride height If the track is not bumpy, try 4.5-5.0mm
Rear
silver springs
40wt AE oil
#2 pistons 1.1mm 3 holes would work better if you want the car aggresive
1.2 rear sway bar
3.0 rear block
droop 3-3.5mm
rear hub spacers 0.75 in front 2.0 in rear change it to 2.0/front, 0.75/rear
2mm spacer under rear camber tie rod Try 1.5mm or stay with 2.0mm and then go #3 hole on tower.
arms all the way back (spacers in front of arms) Should be 2.0mm in front of arm, 0.75 behind of arm.
2 degrees of camber
6mm ride height
Let me know after you try it.
Thanks,
Front
pink springs
40wt AE oil
1.4 front sway bar
droop 2mm on blocks
4mm ackerm
2 of camber
Rear
silver springs
40wt AE oil
1.2 rear sway bar
3.0 rear block
droop 3-3.5mm
2 degrees of camber
6mm ride height
Thanks,
+1 on all the changes Hiro mentioned.
-Korey
-Korey
Could anybody tell me is any good if running with short camberlink?
In fact somebody from 4000Kv gave me the setup then i didn't run yet with it in my 3000KV class, due my car is still totally disassemble.
Best regards
Best regards
I suggest you to try as many combo as possible and feel the difference. You should feel like laying down the shocks like less camber change while the standing shock likes more camber gain.
Also, it also depends where the static (as 1G) piston position is.
Hope it helps.
boxcarracing.org/RC_Car_Racing/rc_car_racing.html#RCraceinfo
youtube.com/user/ocsdriver
Terrible handling HELP!!!!!!
Issue off power loose:
Tires Cs27
Front
Orange Serpent springs (19.5)
35wt Losi oil 3 hole 1.1
1.4 front sway bar
1.5 front toe block
1.5mm under all front suspension blocks.
4mm ackerm
1.5 of camber
5mm ride height
-1 toe
Droop 6mm
Ride height: 5mm
Rear
silver springs
35wt AE oil
3 hole pistons
1.2 rear sway bar
3.0 rear block
droop 5mm
rear hub spacers 2.0 in front 0.75 in rear
1 mm spacer under rear camber tie rod
2.0nn in front of arms 0.75 in the rear
2 degrees of camber
5.5mm ride height
Tires Cs27
Front
1.4 front sway bar
1.5 front toe block
4mm ackerm
1.5 of camber
5mm ride height
-1 toe
Droop 6mm
Ride height: 5mm
Rear
silver springs
35wt AE oil
3 hole pistons
1.2 rear sway bar
3.0 rear block
droop 5mm
2 degrees of camber
5.5mm ride height
is your rear droop over ride height? if so i would think taking some out would keep the car from getting on the nose when the weight transfers
Super Moderator
Tires Cs27
Front
1.4 front sway bar
1.5 front toe block
4mm ackerm
1.5 of camber
5mm ride height
-1 toe
Droop 6mm
Ride height: 5mm
Rear
silver springs
35wt AE oil
3 hole pistons
1.2 rear sway bar
3.0 rear block
droop 5mm
2 degrees of camber
5.5mm ride height
Tires Cs27
Front
1.4 front sway bar
1.5 front toe block
4mm ackerm
1.5 of camber
5mm ride height
-1 toe
Droop 6mm
Ride height: 5mm
Rear
silver springs
35wt AE oil
3 hole pistons
1.2 rear sway bar
3.0 rear block
droop 5mm
2 degrees of camber
5.5mm ride height
New cyclone wish list:
I am not one for the new car talk.......but what would you like on the new or next generation cyclone, for me:
Lipo Chassis ( exotek style...maybe)
Motor mount some thing like mi4 to keep tweak equal side to side and extra adjustment for weight balence, even better if this could be a 'mod' for curennt chassis
More tunabilty for suspension blocks, may be new hole in chassis but also hole so that currennt blocks would fit.
That would be it for me
