View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
Upcoming Event
Greetings all. Just wanted to post an upcoming event at our facility, Valkaria RC Raceway.
Trader Rating: 89 (100%+)
When you put diff fluid in your gear diff and you intend to use a very heavy diff fluid 12.5k or higher like 1mill how much fluid should In put in the diff, Fill it like a regular diff or just enough to coat the gears ??
Advanced Thanks for responses !
What 25.5 motors are u guys liking now....anyone try the reds or new reedy?
fill it like a regular diff
Trader Rating: 7 (89%+)
=AZWiXjAlUtUjxpHCMG6CtKviFHnIYtof97MWbR2JP0DJWzwDN Y2Emhqdo9DM2iybBT0ei162xaSnZOwlSk03fMScGgnD18Yu6Ug zKtKhp8uefTNMVDvC21e5e8wbkRCk1gVpTQ8u3vz9gZwbbAXuU fXyYUj2y9-xr4lf6jLhzV7Qq4l2wjIPfZ6l5i609PO8zbo&__tn__=-UC%2CP-R]U.S.VTA Nationals
top 10 VTA chassis motor esc at the =AZWiXjAlUtUjxpHCMG6CtKviFHnIYtof97MWbR2JP0DJWzwDN Y2Emhqdo9DM2iybBT0ei162xaSnZOwlSk03fMScGgnD18Yu6Ug zKtKhp8uefTNMVDvC21e5e8wbkRCk1gVpTQ8u3vz9gZwbbAXuU fXyYUj2y9-xr4lf6jLhzV7Qq4l2wjIPfZ6l5i609PO8zbo&__tn__=-]K-R]U.S.VTA Nationals1. Manny Flores AMX Motiv HW
2. Justin Lyons AMX R1 Tekin
3. Jim Piersol AMX HW HW
4. Mark Tiamson AMX Motiv ???
5. Derek Cox Xray HW HW
6. Terryl Bowen 3Racing Trinity HW
7. Jeff Mobley AMX Trinity Tekin
8. David Cox Xray HW HW
9. Glen Shreve AMX ??? ???
10. Will Sheffield Xray R1 R1
I hear in the wind that a motiv 25.5 spec motor is coming for Vta and new tires. My opinon a spec motor will ruin the class as it did usgt. But new tires would be welcomed.
I have seen the prototype VTA tires from Gravity RC. I was told the first batch are still in production. I have not heard anything about a spec motor. Jim Dieter from Trinity has told me that almost every 25.5t motor that he has tested are so similar, that making a "spec" motor is pointless. Maybe Rob King can chime in and clear things up.
R/C Tech Elite Member
I think "has killed" is a little hyperbolic. VTA car counts are strong at the tracks I run. The class would certainly benefit from a tire that works more consistently over it's life. I am sure this debate has been buried long ago. I am excited for the possibility of new life given to the class. Thanks Paul!
I think "has killed" is a little hyperbolic. VTA car counts are strong at the tracks I run. The class would certainly benefit from a tire that works more consistently over its life. I am sure this debate has been buried long ago. I am excited for the possibility of new life given to the class. Thanks Paul!
Does anyone know if you can still get pegasus VTA bodies. I am looking for the mustang body.
Are VTAs usually traction or steering limited?
