View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#271
That Chevy II Nova would make a very cool VTA body.
BTW, is anybody interested in a brand new HPI Sprint 2 RTR with 1969 Camaro body?
#272
For the record, if you don't like the HK batteries, the ThunderPower has a 2700 35c ROAR approved hard case battery I have used, and it is available for about $35. There are also 3300 and 4300 batteries in 35c and 60c as well, but they cost more. I'm just adding this since I know they are in production.
As far as spoilers, you should be using the one that came with the body. I guess I'll have to change that. As far as the Mustang, which has no molded in or add on spoiler, I have been considering for a long time to allow a small lexan spoiler to be used. I know Doug Carter had said long ago he had no problem with adding something like that to keep everybody even. I will get that squared away once I measure some of the other spoilers.
Also, X drive testing will commence tomorrow so this issue can finally be put to bed.
#274
#275
#276
#277
I have heard random reports of racers getting more punch out of lower capacity and lower c rating batteries when used in VTA. Has anyone experienced this? I wonder what might cause this phenomenon. It seems to go against conventional wisdom.
#278
I measured the Cuda at 12.8mm and the Javelin closer to 12.4mm. Depending on if I squint or tilt my head like a dog.
#279
Help me wrap my brain around something...
All things being equal--
A 25.5 motor set to the stock timing mark will have:
More punch off the corner, less top end
-whereas a-
25.5 motor set to a higher timing mark (45 degrees for example) will have:
less punch off the corner and more top end.
Why I'm asking-- I've only ever used the 25.5 SS motor on a tight technical track. Now I have both a SS and a Balistic so i'm trying to figure out what the optimum gearing/timing settings are on a larger, flowing track. I feel that i'm pretty close on my chassis setup and driving skills but i've never had to think about motor timing.
-whereas a-
#280
#281
http://events.rcsignup.com/events/di...nt.cfm?ID=2625
I do apologize for the lateness of this as well as the not having the spec tires sooner. This is and should not be any reflection on anyone other than myself for not having them sooner.
We will have a "special" run-in/practice time for USGT on the spec tires for those coming in on Saturday, time TBD. Set of 4 pre-mounts will be under $20.
per Eric
per Eric
#282
per Eric
per Eric
#285
So I wouldn't hold my breath for the '78 Firebird body becoming a legal USVTA body.
