Xray T3 2012
#1411
#1412
spec r
Anyone one use these? They are the version 2.
http://demonpowerproducts.co.uk/prod...t3-pair-p-5352
#1413
After looking at "quick reference table", it's seem that the antiroll bar is very influential in setting, even more influential than the tire. Anybody confirm this?
#1415
for some difficult track. if i use wrong setting to anti-rollbar ,
my car will difficult to drive, and easy to turn-over or over steer.
if i use right anti-rollbar setting, my car can increase speed in the curve.
my XRAY T3 2012 ...
See Surikarn Chaidejsuriya & Meen Vejak , both race on IOC2011 Jan 28-19 2012.
both use XRAY T3 2012, both are the best driver of Thailand now.
This video clip is TC Brushless 10.5T class, MAIN A
+ YouTube Video | |
#1416
According to the "quick reference table", tire is more important than anti-roll bar only on the "straight line stability". For other aspects, tire is equal or lower priority than the anti-roll bar
sorry to be very theoretical, but it is becoming interesting
#1419
xray t3 2012 build tips
just bought myself a new xray t3 2012 any tips on building the kit etc ? thanks
#1420
you just follow instruction on manual with carefully, many assembly tip is in manual already.
at finish you will have a good race car.
i like xray T3 gear-diff so much. it perfect. smooth & strong.
pic of my gear diff, while i assembly it.
#1421
The diff is great, just that I have problems installing the 24x0.7 O-ring... Everytime a diff is rebuilt, a new one must be used
#1422
I don't even bother with it after a team driver told me it was worthless. I haven't run the O-ring since November without any leaking, so I would say just stick with the paper one, and if you're paranoid use the AE green grease or the Losi "Great Grease" for a bit of an extra seal.
#1423
Guys, can you help me track down the following info from XRay drivers at Snowbirds? I'm trying to complete the information here: http://rcprogear.com/tagged/snowbirds12
Class:
Name:
Chassis:
Motor (Turns):
ESC:
Tires:
Battery:
Body:
Radio:
Class:
Name:
Chassis:
Motor (Turns):
ESC:
Tires:
Battery:
Body:
Radio:
#1424
Last time I cut out what was too much and put it in with some green slime and no leakage.
But as said before some team drivers dont use the o-ring at all. Also heard that sometimes 2 gaskets are used.
#1425
One gasket is fine, I don't use the o rings, if anything, they create more chance of leakage as they are easy to catch when fitting the two parts together. All i use is silicone grease and the green gasket.....never leaks!
