Xray T3 2012
#2911
Use new plastic shock bottoms cause the X-ray thread is different and larger making them cross thread and loose. Also trim the 1 mm end off the bottom of the shock shaft
#2912
hi there.. i was wondering if anybody is using a different brand rear belt, i popped mine in my first race and i can't find a replacement that i can get in less than a week.. if anybody knows what fits please share it!! thank you guys..
Yukiyu
Yukiyu
#2914
hot bodies tcx rear belt fits perfectly too
#2915
thank you guys!!
Yukiyu
Yukiyu
#2916
I've been running the TRF shocks with the Tamiya hardware on the top and XRay bottoms, springs, retainers, ball cup. Haven't needed to trim the shock shaft in this configuration, and with the Exotek bits, they look great. I use Tamiya 53599* or 42231** for the ball on the shock tower. You can get away with using the Tamiya hardware on top with the 12's shock towers, it clears just fine. I believe that wasn't the case with the '11 which is why people were trying to use XRay hardware before.
* These parts are gray, not black. The color blends in just fine. They look like this, which incidentally seems to be a new piece I'm not familiar with. It's shorter which might move the shock closer to the tower? I haven't tested it.
** I haven't tested these yet, but I assume they'll work fine. They look HOT.
#2918
I have tried the tamiya shocks and in my opinion there is no performance difference between them and the xray ALU shocks. If you run the alu shocks you have the benefit of being able to directly apply the pro setup sheets, whereas with the tamiya you have to make slight alterations to your shock oil weights to match up depending on your piston configuration.
Alu shocks are a bit more expensive though.....
#2919
#2922
I prefer TC5 shocks.
#2924
Honestly, I'd take the convenience and consistency of toe blocks over the current style, even if it meant keeping a few more parts around. I already spend a small fortune to field this car, what's a few more bucks?
Hey Exotek, here's an opportunity to create some blocks that replace the existing pieces (on an XRay chassis) but are narrower. This sort of upgrade is right up your alley. Make it so!
#2925
One thing to consider with the plastic body shocks is thermal expansion- the plastic bodies are very susceptible to hot and cold and thus shrinkage and expansion. This can cause you to chase your set up from morning to noon to night as the shock body diameter changes therefore causing different dampening effects.... Alloy bodies are a must be it Xray or Tamiya shocks.
