Ask Keven Hebert, TeamAssociated / Reedy / ApexRC
#481
#483
Oil in rear gear diff
Keven,
As a general rule on high traction carpet - what are the affects of lighter oil vs. heavier oil in the rear gear diff? I need just a tiny bit more of mid-corner steering and I think I can get that by simply running heavier oil in the diff (currently running 35wt Associated oil). Should I go heavier? Thanks in advance for the help.
#484
I do not know how it will acct but tc6 and tc6.1 with havy oil in rear end (even stock setup for both) with 1000 or 2000 or 3000 or 5000 ae diff oil is much better for drive, it lost nervous, drive from cornet to corner.
Just try it, I switch to havy oil, maybe some more drop at front end and car is much better and much faster.
But I can be wrong ...
#485
you dont need to do much for the spec-r shaft to fit. All I had to do was to use the 5x10x3 for the inner bearing, use HB Hex and then for the blade, I put a 2mm hex in our curent blade in the hole to make it a tiny bit bigger and then it fits goo on the specr shaft and thats all I had to do !
I wanted to mount the spec-r DCJ made for Tamiya in my TC6.1 so I had followed your instruction. I already bought drive shafts and I'm wondering what size of HB hex did you use, was it 4 mm or 5 mm. I don't also completly understand your words: "then for the blade, I put a 2mm hex in our curent blade in the hole to make it a tiny bit bigger". Please explain it and correct me if I'm wrong. Do i have to dremel c-hub a lil bit to fit?
Thanks in advance.
#486
Dear Keven,
Thanks in advance.
Thanks in advance.
No dremel needed, you can do it manually).
Sébastien
#487
thanks, do you know what about the hex? Maybe tamiya hex also fits?
#488
#489
Tamiya Hex will work or HB hex, or Reflex just cam out with theirs as well in 4 and 5mm so that is a good option too. AE Hex are 5mm
You have a few options, RC9390 just released a DCJ for our car as well and fits the AE Hex and blade.
RSD also has a good dual joint for TC6.
For the blade when running the tamiya, what I meant is that I usualy just stick a 2mm hex driver the tip into the blade hole and spin it fe times and then take it out and it is perfect size ! that is more the ghetto style, if you want to do it right, a drill bit would be best !
#492
1. Sorry I do not have an answer for that one !
2. Absolutely, maybe not so much concidering I am not a big tequila fan BUT, Vodka will do the trick on that sunday.
#493
