EPIC "D3" Duo 3
Old 09-01-2011, 09:45 AM
  #541
I'd define "small, tight track", but I haven't seen it since they redid the layout a few weeks back. I'm guessing no more than 90'x 70' since they were going to put an oval around the outside, but don't know. Wish we could get our ambient temps below 100. Every day in August but 1 was 100 deg+. Thanks for the help, it gets me started. The last time I ran TC was with my MR4TC Worlds car. NiMh batteries and V-brush motors were cutting edge then ha ha. Same issue I had when 1/10 off-road picked up here again. LiPo and BL and programmable speedos are great, but take a little learning.
cjtamu is offline
Old 09-01-2011, 04:14 PM
  #542
Team EAM
Trader Rating: 79 (100%+)
Default New Website!!
The new Team Trinity web site is launching today and at the same time moving to a new server to offer faster access, a new user friendly store and loads of new features which will be debuting over the next couple of months.
While the transfer is taking place you may use www.trinityrc.net to access the site. When the transfer is complete you will be able to use the trinityrc.net or the old www.teamtrinity.com.
EA
EAMotorsports is offline
Old 09-10-2011, 01:53 AM
  #543
duggyload's Avatar
Default 1s D3 7 turn
Hi all i am running 1/12th 1s with a 10.5 epic d2 motor settings are
Boost 52
Start 2437
End 7001
turbo 15
Ramp 3
Delay 0.2
rollout 60mm
This setup is very fast but we are doing nationals at a new track about double the size with 2 very long straights
I have bought a epic d3 7 turn motor
Could somebody give me a few pointers on rollout and settings
Thanks in advance
duggyload is offline
Old 09-11-2011, 12:24 PM
  #544
Bubblehead's Avatar
Originally Posted by EAMotorsports
No the ReVtechs were designed around a large Torque power band. They produce more torque across the board with a slight increase in RPM as well.
EA
Which motor would be better for 17.5 non-boosted Touring Car? ReVtech or D3
The Ad in Xtreme RC for ReVtech: wider power band for running 1-cell oval, 2wd short course and off-road trucks and buggies.
Bubblehead is offline
Old 09-12-2011, 09:45 PM
  #545
kman16jr's Avatar
Trader Rating: 56 (100%+)
hey guys what is the difference between the d3 17.5 and the revtech 17.5 other than the added kv?Im asking this because i just bought a brand new d3 17.5 and wanna know if there is any huge differences between the 2 motors,mine runs great but is the revtech worth buying if i already have the d3 17.5?I run non-boosted tc right now but may run boost later.
kman16jr is offline
Old 09-21-2011, 09:44 AM
  #546
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Ravz
Well needless to say I've had to go back to the drawing board on this one...
I've ordered a new stator and will take an extreemly conservative approach next time.
1. FDR 6.7+
2. Motor Timing 'ZERO' - to start with...
3. Tune RS to get max timing whilst keeping temps way cool
4. Get new and more accurate Temp gun!
I've been running SP b4 and no issues with temps.
I've been in the hobby 3 years+ now and this was my first cooking, bit disappointed I guess!
Check your FDR settings. With all the torque at lower RPMS with endbell timing at 0*, you may want to start at 6.0 and check temps at 5 min. Let it cool and adjust up and down a couple pinion sizes and see what results you get. I run mine with 5* endbell, 40 boost, turbo ramp and other settings about the same and my sweet spot is between 5.4 and 6.0 depending on the track.
liljohn1064 is offline
Old 09-21-2011, 03:33 PM
  #547
I'm looking for a rollout for 17.5 1S 12th for the Duo 3. I'm guessing between the 80 to 85 range boosted with the Tekin RS, but I have never run this motor. This is for Open ESC, I wouldn't mind a rollout for 17.5 no timing also.
Old 10-06-2011, 07:50 PM
  #548
Bubblehead's Avatar
Default End bell timing
How much timing is each mark on the end bell? D3
Old 10-07-2011, 01:31 AM
  #549
M-Technic's Avatar
Trader Rating: 15 (100%+)
8*.
M-Technic is offline
Old 10-16-2011, 06:02 PM
  #550
Buckaroo's Avatar
Originally Posted by M-Technic
8*.
So how much static timing at the center (long, zero, whatever) hash mark?
Buckaroo is offline
Old 10-17-2011, 08:21 AM
  #551
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
anyone have this answer
RaceAce701 is offline
Old 10-17-2011, 08:53 AM
  #552
HarryLeach's Avatar
Center mark is zero timing.
HarryLeach is offline
Old 10-17-2011, 09:18 AM
  #553
Team EAM
Its actually 30 degrees. A BL motor wont run very well at all at true zero timing. Most all motors are 30 at what is called zero timing.
EA
Old 10-17-2011, 10:02 AM
  #554
Buckaroo's Avatar
EA
OK, thanks. That's what I thought, just wanted to confirm.
So, 30* static, 8* per line.
Buckaroo is offline
Old 10-20-2011, 05:36 PM
  #555
Bubblehead's Avatar
What is the difference?
The ad in Xtreme RC Cars: The ReVtech line features a wider power band for 1-cell oval, 2wd short course and off-road trucks and buggies.
What about touring cars?
